I'm probably all wet with this one, and judging from the cars owned by folks replying to this thread...I'm sure I am, but...I think that you could have an awesome, well represented, heads-up NSS class. In my mind it should be much more pure than aluminum-headed, 500 inch plus, mini-tubbed cars. How 'bout running stock displacement +.060 overbore, multi-carb only, 10.5" max tire (would love to see 9" stock eliminator tires used, with steel heads. Basically use the regular NSS rules, but run a minimum weight, and run them heads up. I'm thinking that low-11 second cars could play, but would get beaten pretty easily. A mid-ten second car would be very competative, and only the nastiest, high-budget race cars would run in the high 9's. Heck...make the class a breakout at 9.99! Just sayin'
