84 truck rotor or 76 new yorker rotors get the front
will take an earlier rear axle,cant just swap them/change in c-clip
c-body 8 3/4 is same as truck 8 1/4 or 9 1/4
the shackle flip with front hanger is good for 4-5 inches in the rear with axle floped on top of springs. can flip the front hanger also for another little bit.
A-body 8 3/4 bolts in and tucks 12" rims with 29x15x15 M/Ts in the fenders like mine.(did both my stepside and wide box)
3/4 or 1 ton pocketed lower control arms with stock 1/2 ton spring or shorter for the front,get offset upper bushing to help alinement.
very nice truck
