Re: would you brake in a engine with a new six pack?
[Re: cjs69mope]
#1119152
11/22/11 02:44 PM
11/22/11 02:44 PM
Posts: 75,110 A Banana Republic near you.
JohnRR
what's the problem? Why would it be a bad idea? Just make sure your floats are set (have to do that w/ a 4bbl), then make sure your distrib is clocked right, fill the primary bowl up, turn the mixture screws in all the way then out 1.25 turns, turn the idle screw down (so the engine mantains about 2k) and let her rip. Once it's warm turn the idle up to 22-2400 set your timing in full around 36* (vac advance pluged) get your vacuum gauage out and tune for best signal. Once the 20 minutes are up, change the oil and go for a drive. You can leave the outboards un-hooked if you like, but they aren't going to open until your engine goes under "load" As for cutting the block or heads, sure but make sure the intake will seal before you fire it. If you cut the heads a bunch you'll have to have the intake cut too. I had to have .030 taken off a brand new RPM once.
Yea that is what i was going to do but i was not sure . I have to get the intake cut on the sixpack so i did not want to cut another 4 barrel one too . the block was wacked .012 and heads .060 so i was using the old mopar formual {for every .010 off the deck then .012" needs to be removed from the intake side} Well i come up with .086" off the intake , Not sure if that is total for one side or both .043 on each side =.o86 or .086 on each side? Seams like alot ! not sure how to get this right . the first time .
It would be .086 off each side , but you also have to take int oa ccount the .012 you had cut off the block , that's the same as cutting .012 more off the heads .
Normally the heads would be cut on the intake side so that the intake manifold itself would not have to be cut , I'll assume the head deck was only cut and they intake side of the head was not ?
