Quote: I There was almost NO material covering the top of all of the ports at all. You can see the carbon lines on the manifold along the tops of each port....and it's right at (or maybe past!) the edge of the ports. Not Good.
That's what I had carbon tracks from the wrong gaskets. I dont know about warpage but when I got the ports covered that took care of it.
