No gasket is needed with stock manifolds. Prepare the manifold sealing surface with a 12 in flat mill file to remove any high spots or garbage left on it. I would take the manifold to a muffler shop and hve them braze the shaft holes for the hear riser if you are not going to use it. Clean the head sealing surface and bolt it up.
