Like mentioned before nothing has been removed except the vinyl top. Things added are homemade subframe connectors, which are probably 30 lbs+/-, 1/4" thick driveshaft loop, the 3" exhaust, the steel wheels, Caltrac setup, and my 230 lb girly figure. And that weight was with a full tank of gas too.(the car, not me ). Dana adds a bit too I'm sure.
