Also, I was using a pinion snubber,adjusted 3/4 from floor.I know a lot of you are against them. What will I do in place of one?I have extra heavy duty leaf springs under the car which I cannnot afford to replace right now.
If you get a Strange S-60 it will have tne mounts for a snubber.
Yes it will plus it's easier to set up because of the adjusters for carrier preload.
Quote: Anyone have any thoughts?
Do what you gotta do , if Kammer is recommending the guy then you can't really go wrong there. Do you need the snubber on the rear ?
