Mike,
a friend helped me drill out the 7290 yolk and attached heavier straps and grade 8 bolts/nuts the day before I went to the track.
I removed the yolk for drilling.
I knew I had the 489 with a crush sleeve.
The pig was just freshened with new bearings & pinion seal last fall.
I re-installed the yolk and torqued it to 190 lbs.
I was told by the person who re-built my pig that he torqued it to 225 ft. lbs.
The yolk definately felt different(tighter)after I torqued to 190
I was gonna step it to 225lbs after I reached 190 but stopped because it felt tighter.
The next day after driving it to the track,it broke on the starting line after 1 easy pass to break in the new slicks.
Do you think I probably crushed the sleeve further,and changed the pre-load?
John
