You might want to consider a K-member from a mid 80s 5th Avenue/Diplomat. That would give you the cradle mounts, transverse torsion bars, and disc brakes all in one unit. It could be bolted in or welded to your front subframe. The width should be close but could be fine tuned with the offset of your front wheels.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
