One side of your starter switch should have a fused constant battery power. The other side should go to the Neutral switch, out the neutral switch and to the "s" on the starter relay. At the starter run a small jumper wire from the big post to the small post like in the picture.
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
