Quote: Play around with the thumbwheel dimmer switch on the dash. Go past the notch then up and down.
I'd go with the dash dimmer switch.
Me too, usually the tab/contact that runs against the springy thing wears or bends and loses contact.....sometimes just in different places but in your case completely. I don't remember if I was able to bend the contact and get one to work before or if it was another brand car.....getting too old or spent too much time under the dash the last two days
