I have bench adjusted the shifter stops too tight more than once. Just unscrew the stop all the way out and try some shifts to see if the grind is gone.Readjust stop inward as necc.Clutch plate departure is also very important-but you stated the other gears shift fine.Are you shifting all gears at same rpm? Check for deflection in linkage as previously suggested. Good luck. Chris
