Is the reverse detent working ? there is another thread on this someone else was having a problem wit htheir trans , the ball for the detent is MIA and the lever is not in the correct position when not in reverse
the ball for the detent is there, i can gurantee that...whether or not its in the correct position though im not sure...when i had it apart it looked to be working fine
Did you put the idler for reverse on correctly ? If yes then it's time to look at the syncro
yes, that I am positive about. Did it with my dad who is a mechanic and we made sure of that after the problems i had. I figure it is a synchro...damn i dont feel like pulling this thing out again
