Re: Which oil pickup do I need?
[Re: JoesMopar]
#992693
05/15/11 12:21 PM
05/15/11 12:21 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Pick ups are cheap, you'll never get it clean..Wiping out the bearings & taking out the crank won't be... Keep in mind Doc still has his first penny... I don't have a pt# for you but Melling makes them.. Last Mopar one I bought was around $20.00..
[Re: JoesMopar]
#992694
05/15/11 12:22 PM
05/15/11 12:22 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If it's a baffled you need a dog leg pickup to use with it. They're harder to find than the straight pickup. Yes clean your old one the parts washer is a good start. Compressed air works wonders for getting those chunks to break up.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 1_WILD_RT]
#992695
05/15/11 02:22 PM
05/15/11 02:22 PM
Posts: 30,488 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
OK Mr Money Bags .... ![](/ubbthreads/images/graemlins/laugh2.gif)
I want to see you throw a TWENTY DOLLAR BILL out your window. I think not .... ![](/ubbthreads/images/graemlins/smoke.gif)
All he probably has in-there is a piece of cast-iron or sludge hung-up on the screen. FOR SURE if you can't get that piece outa-there you should not chance-it. That piece of trash could get up into the oil-pump or bearings. It should blow-out with some compressed air.
Just soak the screen-area for a couple of days.
[Re: dOc …]
#992696
05/15/11 03:42 PM
05/15/11 03:42 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Any time you want to know why I won't reuse a pick up screen try cutting one open & see how much crap is really trapped inside.. I made a living working on this junk not being a keyboard commando.. I spend money on stuff because it's cheaper than the alternative... ![](/ubbthreads/images/graemlins/Twocents.gif) Yeah lots of guys reuse screens, the first time you cut one open you'll realize it's a bad idea..
[Re: 1_WILD_RT]
#992699
05/15/11 07:49 PM
05/15/11 07:49 PM
dOc …
Florida STAYcation
I give up.. You guys are right, just reuse it...
GOOD MOVE 1 Wild Keyboard Commando ... it is good-to-see that you admit the errors of your way... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: JoesMopar]
#992702
05/15/11 10:19 PM
05/15/11 10:19 PM
dOc …
Florida STAYcation
Well I tried soaking it and blowing it out, still junk rattling around in there...
What came out so far looks like old seals or gasket material.
Gotta give it more time than a couple of hours ... at least over-nite.
I am redoing a 413 truck motor and I grabbed the PU off of that ...and checked it out. All I did was knock the screen-end on a block of wood(it loosened the crud up) and the stuff came right out.
NO metal in there just valve-stem-seals and what looked like parts of a VC gasket.
[Re: dOc …]
#992703
05/15/11 10:21 PM
05/15/11 10:21 PM
Posts: 2,782 USA
JoesMopar
USA
Sounds exactly like what's in mine.
Thanks for that Mopar link too on the different oil pans Jim
[Re: dOc …]
#992704
05/15/11 10:52 PM
05/15/11 10:52 PM
Posts: 643 southern conn
1969gtx
southern conn
ck on summit part p5007848 it is the dog leg pick up mopar # dcc-5007848
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: dOc …]
#992706
05/16/11 12:07 AM
05/16/11 12:07 AM
Posts: 2,782 USA
JoesMopar
USA
The Summit deal ? ....25 beans plus another 10 clams for shipping ? ...
I know what I would do.
Cheap ass.... ![](/ubbthreads/images/graemlins/laugh2.gif)
Thanks for all the info guys.
I'm soaking it in the parts washer for a few days like Doc mentioned and then I'll see what I can do with it. I actually need to order a few things from Summit so I may pick up that part if I can't get all the junk out of it.
[Re: JoesMopar]
#992707
05/16/11 12:18 AM
05/16/11 12:18 AM
RapidRobert
If you have a bucket of carb soup, it's more caustic
[Re: RapidRobert]
#992708
05/16/11 12:23 AM
05/16/11 12:23 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I'll waste my time one more time.... I've cut them open when they have spent time in a hot tank & look great.... Inside are areas that traps hard debris.... Your motor, your choice...... Oh, might as well add a link too.. http://moparforums.com/forums/f7/black-chunks-jamming-oil-pump-7646/
[Re: 1_WILD_RT]
#992709
05/16/11 12:57 AM
05/16/11 12:57 AM
RapidRobert
Yeah I was real hesitant to even post ![](/ubbthreads/images/graemlins/wink.gif) but now that I have ![](/ubbthreads/images/graemlins/blush.gif) for the record I too would spring for a new one & I'm a believer in going to 1/2" (even on a SB) pickup and doing extensive oiling mods. "bottom line ![](/ubbthreads/images/graemlins/Twocents.gif) rod journals need to b fed & they're at the end of the line"
