Which oil pickup do I need? #992690
05/15/11 11:49 AM
05/15/11 11:49 AM
USA
JoesMopar Offline OP
USA
I am using a "971" oil pan on my 383. This is a baffled pan with a windage tray. I have the pickup, but it's loaded with junk I can hear rattling around inside of it. I was wondering if anyone had a part # that would work for this particular oil pan.
Re: Which oil pickup do I need? [Re: JoesMopar] #992691
05/15/11 11:56 AM
05/15/11 11:56 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Just give the PU a good soak and that junk should come out OK.
Re: Which oil pickup do I need? [Re: dOrk !] #992692
05/15/11 12:02 PM
05/15/11 12:02 PM
USA
USA
Like hot water and Simple Green or soap? I have a parts washer I could also put it in if that would be better?
I read that this pan is actually from a '73-'78, I'm putting it in a '68 Satellite. Any idea if this thing will even fit? It was in a '69 Charger so I'm ASSuming it would.
Re: Which oil pickup do I need? [Re: JoesMopar] #992693
05/15/11 12:21 PM
05/15/11 12:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pick ups are cheap, you'll never get it clean..Wiping out the bearings & taking out the crank won't be... Keep in mind Doc still has his first penny... I don't have a pt# for you but Melling makes them.. Last Mopar one I bought was around $20.00..
Re: Which oil pickup do I need? [Re: JoesMopar] #992694
05/15/11 12:22 PM
05/15/11 12:22 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If it's a baffled you need a dog leg pickup to use with it. They're harder to find than the straight pickup. Yes clean your old one the parts washer is a good start. Compressed air works wonders for getting those chunks to break up.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Which oil pickup do I need? [Re: 1_WILD_RT] #992695
05/15/11 02:22 PM
05/15/11 02:22 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
OK Mr Money Bags ....
I want to see you throw a TWENTY DOLLAR BILL out your window. I think not ....
All he probably has in-there is a piece of cast-iron or sludge hung-up on the screen. FOR SURE if you can't get that piece outa-there you should not chance-it. That piece of trash could get up into the oil-pump or bearings. It should blow-out with some compressed air.
Just soak the screen-area for a couple of days.
Re: Which oil pickup do I need? [Re: dOrk !] #992696
05/15/11 03:42 PM
05/15/11 03:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Any time you want to know why I won't reuse a pick up screen try cutting one open & see how much crap is really trapped inside.. I made a living working on this junk not being a keyboard commando.. I spend money on stuff because it's cheaper than the alternative... Yeah lots of guys reuse screens, the first time you cut one open you'll realize it's a bad idea..
Re: Which oil pickup do I need? [Re: 1_WILD_RT] #992697
05/15/11 03:48 PM
05/15/11 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The filter is between the pickup and the bearings/crank.
On hard to find pickups I always throw them in the hot tank with the block..they'll come out as clean as the block.
Re: Which oil pickup do I need? [Re: John_Kunkel] #992698
05/15/11 03:59 PM
05/15/11 03:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I give up.. You guys are right, just reuse it... He's not working on a max wedge, it's a fairly common pick-up tube, my local production machine shop stocks hundreds of styles I can have one on Monday...The fact that they race Mopars doesn't hurt, they know the part number & they stock it...
Re: Which oil pickup do I need? [Re: 1_WILD_RT] #992699
05/15/11 07:49 PM
05/15/11 07:49 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
GOOD MOVE 1 Wild Keyboard Commando ... it is good-to-see that you admit the errors of your way...
Re: Which oil pickup do I need? [Re: dOrk !] #992700
05/15/11 09:10 PM
05/15/11 09:10 PM
USA
USA
Well I tried soaking it and blowing it out, still junk rattling around in there...
What came out so far looks like old seals or gasket material.
Re: Which oil pickup do I need? [Re: JoesMopar] #992701
05/15/11 10:04 PM
05/15/11 10:04 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
This link might help you with the part#
http://www.mymopar.com/oilpanspecs.htm
69 Roadrunner 383 stock
Re: Which oil pickup do I need? [Re: JoesMopar] #992702
05/15/11 10:19 PM
05/15/11 10:19 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Gotta give it more time than a couple of hours ... at least over-nite.
I am redoing a 413 truck motor and I grabbed the PU off of that ...and checked it out. All I did was knock the screen-end on a block of wood(it loosened the crud up) and the stuff came right out.
NO metal in there just valve-stem-seals and what looked like parts of a VC gasket.
Re: Which oil pickup do I need? [Re: dOrk !] #992703
05/15/11 10:21 PM
05/15/11 10:21 PM
USA
USA
Sounds exactly like what's in mine.
Thanks for that Mopar link too on the different oil pans Jim
Re: Which oil pickup do I need? [Re: dOrk !] #992704
05/15/11 10:52 PM
05/15/11 10:52 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
ck on summit part p5007848 it is the dog leg pick up mopar # dcc-5007848
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Which oil pickup do I need? [Re: 1969gtx] #992705
05/15/11 11:25 PM
05/15/11 11:25 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
The Summit deal ? ....25 beans plus another 10 clams for shipping ? ...
I know what I would do.
Re: Which oil pickup do I need? [Re: dOrk !] #992706
05/16/11 12:07 AM
05/16/11 12:07 AM
USA
USA
Cheap ass....
Thanks for all the info guys.
I'm soaking it in the parts washer for a few days like Doc mentioned and then I'll see what I can do with it. I actually need to order a few things from Summit so I may pick up that part if I can't get all the junk out of it.
Re: Which oil pickup do I need? [Re: JoesMopar] #992707
05/16/11 12:18 AM
05/16/11 12:18 AM
If you have a bucket of carb soup, it's more caustic
Re: Which oil pickup do I need? [Re: RapidRobert] #992708
05/16/11 12:23 AM
05/16/11 12:23 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'll waste my time one more time.... I've cut them open when they have spent time in a hot tank & look great.... Inside are areas that traps hard debris.... Your motor, your choice......
Oh, might as well add a link too..
http://moparforums.com/forums/f7/black-chunks-jamming-oil-pump-7646/
Re: Which oil pickup do I need? [Re: 1_WILD_RT] #992709
05/16/11 12:57 AM
05/16/11 12:57 AM
Yeah I was real hesitant to even post but now that I have for the record I too would spring for a new one & I'm a believer in going to 1/2" (even on a SB) pickup and doing extensive oiling mods. "bottom line rod journals need to b fed & they're at the end of the line"
