Turn Signal Problem... #98881
08/03/08 08:25 AM
08/03/08 08:25 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Hi Guys, I have a 1978 Dodge Aspen, and lately my turn signals have been acting up.
Both signals will turn on, then occasionally stop flashing, when turning left or right. They will either:
1) not flash from git-go,
2) will flash normally,
3) will flash normally then stop,
4) will flash then stop then re-start.
All the lights are fine.
Any clue on where to start? Bad relay? If so, is there only one?
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Turn Signal Problem... [Re: cuda_tim] #98882
08/03/08 08:37 AM
08/03/08 08:37 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Sounds like your 552 flasher is bad.
Re: Turn Signal Problem... [Re: GODSCOUNTRY340] #98883
08/03/08 08:43 AM
08/03/08 08:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Or that your battery is low and the alternator isn't charging enough to keep up the voltage needed to trip the breaker/flasher till it is up off engine idle or up to faster engine speeds.
Re: Turn Signal Problem... [Re: GODSCOUNTRY340] #98884
08/03/08 08:51 AM
08/03/08 08:51 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Does it control both turn signals?
Re: Turn Signal Problem... [Re: MoparforLife] #98885
08/03/08 08:52 AM
08/03/08 08:52 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Speed doesn't seem to matter. Although it does affect it some. I can be going down the road at 50mpg and the turn signal will work but then stop.
Re: Turn Signal Problem... [Re: cuda_tim] #98886
08/03/08 08:52 AM
08/03/08 08:52 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Yes it does... (Flasher works both turn signals)
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Turn Signal Problem... [Re: GODSCOUNTRY340] #98887
08/03/08 09:26 AM
08/03/08 09:26 AM
yes most likely & there's another flasher for the emergency flashers so pull the right one. Pull on the E flashers & pull the can that is not clicking. IF not the flasher can, clean sockets & check bulbs.
Re: Turn Signal Problem... [Re: cuda_tim] #98888
08/03/08 09:34 AM
08/03/08 09:34 AM
Making turns @ 50mph??!!
Re: Turn Signal Problem... #98889
08/03/08 10:07 AM
08/03/08 10:07 AM
Upper Midwest
Upper Midwest
Try to clean your battery posts and clamps and make sure that they are good and tight and have shiny connections. Check grounds& flasher. There should be 2 of them one for the 4 ways and the other for the turn signals.
Re: Turn Signal Problem... #98890
08/04/08 11:04 AM
08/04/08 11:04 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
[quote Making turns @ 50mph??!!
Sure, don't you?
Obviously I wouldn't try it with a Furd or Chev...
But seriously, I just tried using the signals (at that speed) in order to check and see if it did have something to do with my charging system.
And it didn't...
Swapping out the relay fixed it.
Thanks, guys!!!
