Turn Signal Problem...
#98881
08/03/08 08:25 AM
08/03/08 08:25 AM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
Hi Guys, I have a 1978 Dodge Aspen, and lately my turn signals have been acting up.
Both signals will turn on, then occasionally stop flashing, when turning left or right. They will either:
1) not flash from git-go, 2) will flash normally, 3) will flash normally then stop, 4) will flash then stop then re-start.
All the lights are fine.
Any clue on where to start? Bad relay? If so, is there only one?
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Turn Signal Problem...
[Re: cuda_tim]
#98886
08/03/08 08:52 AM
08/03/08 08:52 AM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Yes it does... (Flasher works both turn signals)
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: cuda_tim]
#98888
08/03/08 09:34 AM
08/03/08 09:34 AM
Or that your battery is low and the alternator isn't charging enough to keep up the voltage needed to trip the breaker/flasher till it is up off engine idle or up to faster engine speeds.
Speed doesn't seem to matter. Although it does affect it some. I can be going down the road at 50mpg and the turn signal will work but then stop.
Making turns @ 50mph??!!
