Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!!
[Re: 392charger]
#934161
03/04/11 02:45 PM
03/04/11 02:45 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
The suspense is just killing me so give us an update when you can.
![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: blownzoom440]
#934162
03/04/11 02:57 PM
03/04/11 02:57 PM
Posts: 42 England
pete walton
England
THis must be catching,,,,My brand new 493 stroker leaked like it had been shot from the rear seal,My set up is a brand new Eagle crank ,,,BCR ali main caps with the MP performance billet rear seal...Done the usual fixes no joy ...Found that Mancini,s do a rear main bearing that has a groove to take pressure away from rear seal ,,,,, Changed it from underneath ,,,bit fiddley but i have had a bit of practice ....Problem i think is solved,,,test will be at the track ,,,,Hope this helps
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP
[Re: blownzoom440]
#934167
03/21/11 06:25 PM
03/21/11 06:25 PM
Posts: 255 Washington, Pa
runner12
Washington, Pa
UPDATE!!! crank is cracked in several places ..called the guy who built the engin ..your converter must be hitting the crank and cracked it!!! [Edited by Moparts - Family Friendly Site - Keep it clean]!! is that? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) He blamed it on everything else but the crank . ![](/ubbthreads/images/graemlins/down.gif) I need a deal on a 4.15 stroke crank for a440 6 bolt flange ![](/ubbthreads/images/graemlins/smilie_help.gif) Thanks moparts . sorry ![](/ubbthreads/images/graemlins/frowwn.gif)
[Re: runner12]
#934168
03/21/11 06:40 PM
03/21/11 06:40 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
UPDATE!!! crank is cracked in several places ..called the guy who built the engin ..your converter must be hitting the crank and cracked it!!! [Edited by Moparts - Family Friendly Site - Keep it clean]!! is that? He blamed it on everything else but the crank . I need a deal on a 4.15 stroke crank for a440 6 bolt flange Thanks moparts . sorry
Call John at Hawk racing, 951-369-0200 and ask them about current prices, if in stock or not and shipping costs on one to you I have used several of there Chinese imports in motor, no problems so far, including beating the snot out of the motors Like all things, have it check by someone you trust as soon as you get it to make sure it is useable ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: runner12]
#934171
03/21/11 08:38 PM
03/21/11 08:38 PM
blownzoom440
ELYRIA,OH
Yes, I still have the rest of the engin but a look at the pistons and it looks as if the rings were not properly spaced ... so what else is wrong???
i have been there.check everything,get help if needed.lots of help on this and other sites. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: runner12]
#934172
03/21/11 11:12 PM
03/21/11 11:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 4.15 Callies... turned down to move the weight in closer to the center line... not cheap ![](/ubbthreads/images/graemlins/wave.gif)
[Re: runner12]
#934178
03/22/11 10:17 PM
03/22/11 10:17 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
i don't think a crack could cause a vibration, but just wanted to check with you on that, put mine back together today with the new mancini seal retainer and seal, see what happens,i did find the seal in the original retainer was not sitting flush on one end and also there was oil behind the side seals, hopefully that was the problem, now i need to get the caps on the master cylinder to quit leaking, i have the mopar plastic reservoir one ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) .
