Page 4 of 4 1 2 3 4
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: Oyvind Mopar] #934160
03/04/11 01:50 PM
03/04/11 01:50 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
The suspense is just killing me so give us an update when you can.
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: 392charger] #934161
03/04/11 02:45 PM
03/04/11 02:45 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: blownzoom440] #934162
03/04/11 02:57 PM
03/04/11 02:57 PM
England
P
pete walton Offline
pete walton  Offline
P
England
THis must be catching,,,,My brand new 493 stroker leaked like it had been shot from the rear seal,My set up is a brand new Eagle crank ,,,BCR ali main caps with the MP performance billet rear seal...Done the usual fixes no joy ...Found that Mancini,s do a rear main bearing that has a groove to take pressure away from rear seal ,,,,, Changed it from underneath ,,,bit fiddley but i have had a bit of practice ....Problem i think is solved,,,test will be at the track ,,,,Hope this helps
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: pete walton] #934163
03/04/11 04:08 PM
03/04/11 04:08 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I will be the first to admit that over the years my addiction to buying used small and big block Mopar engines (340's, 360's, 440's)has grown. I usually strip them down and scrap the parts I won't be using and store the rest for future projects. I can't tell you how many times I have taken these engines apart and the rear seal has been installed backwards. I think someone should take a good picture of one installed properly and place it in the archives.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: pittsburghracer] #934164
03/04/11 06:50 PM
03/04/11 06:50 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I can assure all of you that the rear main seal is in properly, I understand and appreciate all of the input and will let all of you know asap. Thanks NICK
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: pittsburghracer] #934165
03/09/11 11:13 PM
03/09/11 11:13 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
UPDATE: THE CRANK IS COMING OUT AND HEADED TO BE MAGED AND MIKED AND CHECKED TO SEE IF ITS OUT OF ROUND IN THE BACK WHERE THE SEAL MEETS. MOOR MONEY
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!! [Re: runner12] #934166
03/10/11 12:02 AM
03/10/11 12:02 AM
ELYRIA,OH
ELYRIA,OH
sorry to hear it but this is the only time 1 wants something to be wrong so it can be fixed.good luck!
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: blownzoom440] #934167
03/21/11 06:25 PM
03/21/11 06:25 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
UPDATE!!! crank is cracked in several places ..called the guy who built the engin ..your converter must be hitting the crank and cracked it!!! [Edited by Moparts - Family Friendly Site - Keep it clean]!! is that? He blamed it on everything else but the crank . I need a deal on a 4.15 stroke crank for a440 6 bolt flange Thanks moparts . sorry
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934168
03/21/11 06:40 PM
03/21/11 06:40 PM
Call John at Hawk racing, 951-369-0200 and ask them about current prices, if in stock or not and shipping costs on one to you I have used several of there Chinese imports in motor, no problems so far, including beating the snot out of the motors Like all things, have it check by someone you trust as soon as you get it to make sure it is useable
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934169
03/21/11 07:08 PM
03/21/11 07:08 PM
ELYRIA,OH
ELYRIA,OH
bummer on the crank! the good thing is you still have the rest of the engine.
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: blownzoom440] #934170
03/21/11 08:02 PM
03/21/11 08:02 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
Yes, I still have the rest of the engin but a look at the pistons and it looks as if the rings were not properly spaced ... so what else is wrong???
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934171
03/21/11 08:38 PM
03/21/11 08:38 PM
ELYRIA,OH
ELYRIA,OH
i have been there.check everything,get help if needed.lots of help on this and other sites.
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934172
03/21/11 11:12 PM
03/21/11 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 4.15 Callies... turned down to move the weight
in closer to the center line... not cheap
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: MR_P_BODY] #934173
03/21/11 11:19 PM
03/21/11 11:19 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
Thanks MR.P but im on a tight budget ...the motor is tore down 3 times in 3 years.I should get stock in fel-pro!!
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934174
03/21/11 11:25 PM
03/21/11 11:25 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What was cracked on the crank to cause the oil leak? Was it about to break in half?
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: rowin4] #934175
03/21/11 11:38 PM
03/21/11 11:38 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I dont think it was ready to snap in half but the guy said they maged it and it showed several cracks in different parts of the crank, I have not seen it yet. Either way its not good.
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934176
03/22/11 12:03 AM
03/22/11 12:03 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
not sure but did you get a chance to drive the car? was there any vibration? i just tore into a fresh hemi today to fix an oil leak that i think is coming from the rear main seal, got a mancini billet kit, but i have been chasing a vibration in this car for a while at about 60mph when i let off, does not do it if you hold the car in second, yes new driveshaft balanced twice, checked everything else over and over, hopefully its not a cracked crank.
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: SV_MOPARS] #934177
03/22/11 09:29 PM
03/22/11 09:29 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
Yes I drove it to work and to get gas ,didnt seem to have a bad vibration. With magnafluxing , from what I understand there is liquid and powder mine was liquid and checked with a black light . The guy called and said it hadseveral cracks so I will take his word thats what he does. I just ordered a new crank ,bearings gaskets ect..IM BROKE!!
Re: [b]MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP [Re: runner12] #934178
03/22/11 10:17 PM
03/22/11 10:17 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
i don't think a crack could cause a vibration, but just wanted to check with you on that, put mine back together today with the new mancini seal retainer and seal, see what happens,i did find the seal in the original retainer was not sitting flush on one end and also there was oil behind the side seals, hopefully that was the problem, now i need to get the caps on the master cylinder to quit leaking, i have the mopar plastic reservoir one .
Page 4 of 4 1 2 3 4
