Re: building back half car
[Re: CHAPPER]
#903310
02/26/11 11:39 PM
02/26/11 11:39 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Looks like you pretty much have clearance for about anything you want to put about anywhere you want to put it!! What are you going to use for a car to attach everything to?? Just kidding. I am not trying to offend you,,,I just think that I would be sort of 'intimidated' by the project every time I went into the garage. I have gotten into some big jobs like this in the past, but, don't think I will live long enough to do one like this now. Good luck and keep us posted with pics.
Gotta' feel GOOD getting this far along ...Looking good!! Keep at it
Thanks. I took some time and ground down all four vertical welds on the front area of the crossmember. Actually, I ground 2 of them down twice because I still didn't like the way they looked. I think I am starting to get the hang of it somewhat. I played around alot with the wirespeed and I might leave these as is. Here is what they look like. I know they don;t look great , but I feel they are strong.
I started to fine tune the fit of the quarters and tailpanel, and I am getting the filler panel and trunk gutters in on Monday. I am also looking at parachute mounts so that I can install the mount before the rear valence is final welded in.
More to come, Greg.
[Re: Chargerfan68]
#903313
02/27/11 12:23 AM
02/27/11 12:23 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
No more grinding.. If you keep welding and grinding you will effectively weaken the material by reheating it and embedding impurities from the grinder into the steel and crystalizing the steel changing the molecular structure. Really just making the metal brittle is what I'm saying The only real part that concerns me is in the first picture 3/4" down from the seam you have some cold lap/roll and a crack could start from here. The other thing that I see an issue with is the bottom of your frame rails hang below the cross member. I feel to make this a sound weld it should have been cut .25" shorter than the bottom of the cross member and boxed in so it could be welded %100. Will it be a problem???? Probably not, but a crack could start from the bottom and work it's way up. You could probably just take a 9" and a blue wheel and cut it free hand pretty easy. Just take care not to gouge the cross member. Then box the end in and practice your overheads
[Re: Chargerfan68]
#903316
04/06/11 12:57 AM
04/06/11 12:57 AM
Damn dude! you are just flying along. looks killer.
[Re: gsmopar]
#903320
04/08/11 11:58 PM
04/08/11 11:58 PM
Chargerfan68
New York, USA
Thanks very much for the comps. Your help has definitely allowed me to get this far. Greg.
[Re: Chargerfan68]
#903323
04/09/11 04:42 PM
04/09/11 04:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Those quarters look great... where did you get them... I did quarters on a 70 Charger some time back and I had 3 times the amount of time into them to look nice as I did to hang them
[Re: positivenoise]
#903328
04/14/11 01:04 AM
04/14/11 01:04 AM
Chargerfan68
New York, USA
Wow, I came across this thread. You are doing a great job. The car is looking super. My question is what do you do for a living? If you are not a welder, bodyman, or chassis builder, again Wow, hats off to you.Keep the pictures coming. You are doing exactly what I would love to do to my car.
Thanks very much. I am not a welder or chassis man by trade. I am not even involved with automobiles for work. It just helps that I try to spend almost every waking minute learning and reading about building cars. It is just a love. I never attempted anything like this (at this level). I can tell you that you can do it if you really want to. You just go as slow as you need and measure eveything 3 times to make sure it all goes right. I have been making mistakes, but I just correct and adjust my plans as I go.
It does help that I do have some experience with body and paint work on the side. But that does nothing for me with welding and chassiswork building.
What car would you like to do and how far would you like to go. Some details would be great.
Greg.
