C-body front disc brakes? #899666
01/08/11 05:28 PM
01/08/11 05:28 PM
Polson, MT
DoctorDiff Offline OP
Polson, MT
What was the first year single piston disc brakes were available on C-bodies?
Do these parts interchange with '70-'72 C-body disc brakes?
Re: C-body front disc brakes? [Re: DoctorDiff] #899667
01/08/11 06:00 PM
01/08/11 06:00 PM
Andrewh Offline
Andrewh  Offline
should be 69 I think.
The rotors are 2 piece till 72, and should be the same.
calipers too, till the change in 73, though honestly I am not sure if the 73 caliper is different. I know the spindle and rotor are different in 73 only. That is the 73 rotors do not work on 72 and back spindles, and vice versa. Even though they bolt up to the suspension the same.
The spindles bolt up from 65-73, with the exception of the budd disc to 68. The exception there is supposed to be the lower ball joint is different for the budd disc vs the drum and later disc ball joint.
Though there was some debate on this, no one really had both side by side to verify and it is too expensive to get any lower ball joint for a cbody let alone the budd discs to verify.
Re: C-body front disc brakes? [Re: Andrewh] #899668
01/08/11 08:14 PM
01/08/11 08:14 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: C-body front disc brakes? [Re: Andrewh] #899669
01/08/11 09:08 PM
01/08/11 09:08 PM
Polson, MT
Polson, MT
Thanks for the information.
I just had a batch of spindle sleeves machined, so the readily available '73 C-body/'75 pickup rotors will work with the earlier C-body knuckles.
Re: C-body front disc brakes? [Re: DoctorDiff] #899670
01/08/11 09:33 PM
01/08/11 09:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you!
Re: C-body front disc brakes? [Re: DoctorDiff] #899671
01/08/11 09:37 PM
01/08/11 09:37 PM
hemi71x Offline
hemi71x  Offline
I have a complete BUDD disc brake system off a 69 Imperial in my storage locker.
I took some pictures back in 2008 when i cleaned everything up.
I will post some pictures what those BUDD spindles, and ball joint, tie rod, arms look like.
Maybe it might be of interest to you guys.
That old Chinese phrase, "A picture is worth a thousand words."
Picture #1 Spindles
Re: C-body front disc brakes? [Re: hemi71x] #899672
01/08/11 09:38 PM
01/08/11 09:38 PM
hemi71x Offline
hemi71x  Offline
Picture #2 Back side of spindles.
Re: C-body front disc brakes? [Re: hemi71x] #899673
01/08/11 09:40 PM
01/08/11 09:40 PM
hemi71x Offline
hemi71x  Offline
Picture #3 Tie rod, ball joint arm.
Re: C-body front disc brakes? [Re: hemi71x] #899674
01/08/11 09:45 PM
01/08/11 09:45 PM
hemi71x Offline
hemi71x  Offline
Picture #4 BUDD Rotors & Hubs
Re: C-body front disc brakes? [Re: hemi71x] #899675
01/09/11 12:06 AM
01/09/11 12:06 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Yup, they were pin-type.
Year range Rotor dia. Rotor Thickness Caliper type Eff. Piston area, in2
1966-’68 11.87" 0.875" Fixed 8.85
1969-‘73* 11.75 1.125 Pin 5.93
1974-‘78 11.75 1.25 Slider 7.54
* - note that 1973 (and some late ‘72s) uses a one-pc. rotor and requires a unique knuckle (or the new Dr. Diff adapter sleeve)
Rick
Re: C-body front disc brakes? [Re: Rick_Ehrenberg] #899676
01/09/11 09:02 AM
01/09/11 09:02 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 69 Imp had Budds also.It was a pain to get the seal back then.The 3 70 Imps I had all had single piston calipars.Rocky
Chrysler Firepower
Re: C-body front disc brakes? [Re: hemi71x] #899677
01/09/11 11:34 AM
01/09/11 11:34 AM
33950
67Monaco Offline
67Monaco  Offline
33950
Don't let me find our address.....
I've got a set on my 67 and I'm dreading when it comes time to seriously working on the front brakes. Or ball joints.
Re: C-body front disc brakes? [Re: 67Monaco] #899678
01/09/11 12:23 PM
01/09/11 12:23 PM
hemi71x Offline
hemi71x  Offline
Those BUDD calipers are extremely expensive to try and rebuild.
Everyone that has them feels your pain.
These BUDD calipers would need the full treatment.
The piston bores are pitted, so they would need to be resleaved, the pistons are all corroded away, and reproduction kits from a restoration brake shop that i found in Florida, are very pricey for pieces of rubber.
When it comes time for you to get into your brakes, check out calipersonline.
Re: C-body front disc brakes? [Re: hemi71x] #899679
01/09/11 12:52 PM
01/09/11 12:52 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I don't know about rotor and/or spindle interchanges , but I thought 1969 was still using the 4 piston caliper and 1970 was the 1st year for the single piston caliper
Re: C-body front disc brakes? [Re: hemi71x] #899680
01/09/11 01:43 PM
01/09/11 01:43 PM
33950
67Monaco Offline
67Monaco  Offline
33950
Remanufactured calipers aren't that bad. From what I've seen Cardone's are coming down in price recently. My biggest concern is rotors and ball joints.
Re: C-body front disc brakes? [Re: gtx6970] #899681
01/09/11 02:12 PM
01/09/11 02:12 PM
hemi71x Offline
hemi71x  Offline
Imperials used the Budd disc brakes up till 1969
C bodys used the Budd's up until 1968
Re: C-body front disc brakes? [Re: hemi71x] #899682
01/09/11 04:58 PM
01/09/11 04:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know I sold a guy with a 68 Imp my Frt brake set up.He gladly paid 200 for them.He also bought my like new rear drums and a NOS E brake cable.After I scrapped a bunch of sheet metal I had a bunch of guys wanting it.Rocky
Chrysler Firepower
Re: C-body front disc brakes? [Re: hemi71x] #899683
01/09/11 07:39 PM
01/09/11 07:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Those are some serious spindles! I haven't looked at mine yet. The Imperial is waiting patiently for the hot rod to be done.
- Stu Harmon
Re: C-body front disc brakes? [Re: 67Monaco] #899684
01/10/11 02:38 AM
01/10/11 02:38 AM
Canada
CrAzYMoPaRGuY Offline
Canada
You would hate me even MORE!
I just tossed a GOOD Budd setup about a year ago, couldn't find anybody to GIVE them away to!
I might have a few C body single piston brake parts/pieces around if somebody local wants them... but I'm tossing stuff like crazy. Flip-a-coin Gary has got a lot of donations...
CrAzYMoPaRGuY
Re: C-body front disc brakes? [Re: CrAzYMoPaRGuY] #899685
01/11/11 11:40 AM
01/11/11 11:40 AM
33950
67Monaco Offline
67Monaco  Offline
33950
ugg.
