Re: C-body front disc brakes?
[Re: DoctorDiff]
#899670
01/08/11 09:33 PM
01/08/11 09:33 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Thanks for the information.
I just had a batch of spindle sleeves machined, so the readily available '73 C-body/'75 pickup rotors will work with the earlier C-body knuckles.
Thank you!
[Re: DoctorDiff]
#899671
01/08/11 09:37 PM
01/08/11 09:37 PM
Posts: 5,363 Rancho Cordova, California (Sa...
hemi71x
I have a complete BUDD disc brake system off a 69 Imperial in my storage locker. I took some pictures back in 2008 when i cleaned everything up. I will post some pictures what those BUDD spindles, and ball joint, tie rod, arms look like. Maybe it might be of interest to you guys. That old Chinese phrase, "A picture is worth a thousand words."
Picture #1 Spindles
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#899675
01/09/11 12:06 AM
01/09/11 12:06 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
should be 69 I think.
Yup, they were pin-type.
Year range Rotor dia. Rotor Thickness Caliper type Eff. Piston area, in2 1966-’68 11.87" 0.875" Fixed 8.85 1969-‘73* 11.75 1.125 Pin 5.93 1974-‘78 11.75 1.25 Slider 7.54
* - note that 1973 (and some late ‘72s) uses a one-pc. rotor and requires a unique knuckle (or the new Dr. Diff adapter sleeve)
Rick
[Re: Rick_Ehrenberg]
#899676
01/09/11 09:02 AM
01/09/11 09:02 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
My 69 Imp had Budds also.It was a pain to get the seal back then.The 3 70 Imps I had all had single piston calipars.Rocky
Chrysler Firepower
[Re: 67Monaco]
#899678
01/09/11 12:23 PM
01/09/11 12:23 PM
hemi71x
I've got a set on my 67 and I'm dreading when it comes time to seriously working on the front brakes. Or ball joints.
Those BUDD calipers are extremely expensive to try and rebuild. Everyone that has them feels your pain. These BUDD calipers would need the full treatment. The piston bores are pitted, so they would need to be resleaved, the pistons are all corroded away, and reproduction kits from a restoration brake shop that i found in Florida, are very pricey for pieces of rubber. When it comes time for you to get into your brakes, check out calipersonline.
[Re: hemi71x]
#899680
01/09/11 01:43 PM
01/09/11 01:43 PM
67Monaco
33950
Remanufactured calipers aren't that bad. From what I've seen Cardone's are coming down in price recently. My biggest concern is rotors and ball joints.
[Re: hemi71x]
#899682
01/09/11 04:58 PM
01/09/11 04:58 PM
therocks
Niles , Ohio
I know I sold a guy with a 68 Imp my Frt brake set up.He gladly paid 200 for them.He also bought my like new rear drums and a NOS E brake cable.After I scrapped a bunch of sheet metal I had a bunch of guys wanting it.Rocky
Chrysler Firepower
