70 Challenger drive shaft length #849482
11/09/10 10:51 AM
11/09/10 10:51 AM
Northern Territory, Australia
Z
Zapp Offline OP
Zapp  Offline OP
Z
Sorry if this is covered somewhere I couldnt find it.
I need all lengths necessary to order a driveshaft for my Challenger.
I have Hemi, 727 and Strange Dana that Im having Cass build soon.
Thanks for any help even if its to say look here idiot..............and a link
Re: 70 Challenger drive shat length [Re: Zapp] #849483
11/09/10 11:06 AM
11/09/10 11:06 AM
GA
Boosted Offline
Boosted  Offline
GA
I asked this same question and the result was that I need to buy a yoke.. slip it in the trans to where there is about 3/4 to 1" out and measure center of joint to the center of the joint on the rear-end to get a true shaft..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 70 Challenger drive shat length [Re: Boosted] #849484
11/09/10 12:06 PM
11/09/10 12:06 PM
Z
Zapp Offline OP
Zapp  Offline OP
Z
Thats exactly what Id do except the car is still on Rotisserie and I dont have the diff yet. I just want to make the most of our strong Aussie Dollar and buy some bits now to save some bucks
Re: 70 Challenger drive shaft length [Re: Zapp] #849485
11/09/10 12:32 PM
11/09/10 12:32 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: 70 Challenger drive shat length [Re: Zapp] #849486
11/09/10 12:33 PM
11/09/10 12:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Save your time and money by waiting until you can get a real measurement. A 1/2" off either way and you will be redoing the shaft.
Re: 70 Challenger drive shat length [Re: stumpy] #849487
11/09/10 07:33 PM
11/09/10 07:33 PM
BDW Offline
BDW  Offline
If your motor is located in the stock position, the stock length driveshaft will work.
They didn't custom build each part.
Re: 70 Challenger drive shat length [Re: Boosted] #849488
11/10/10 03:05 AM
11/10/10 03:05 AM
Southwest, Mi.
74Cuda Offline
74Cuda  Offline
Southwest, Mi.
This 1" rule works great, Just make sure the the car is sitting on the wheels or the rear axle is on jack stands before you measure it.
Re: 70 Challenger drive shat length [Re: 74Cuda] #849489
11/10/10 10:00 AM
11/10/10 10:00 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
The rear axle should be on jack stands so the suspension is loaded with the cars weight for a good measurement.
Logan426
Re: 70 Challenger drive shat length [Re: BDW] #849490
11/10/10 10:36 AM
11/10/10 10:36 AM
Z
Zapp Offline OP
Zapp  Offline OP
Z
That is what i was thinking, Im using Schumacher mounts and will confirm with Cass that the Strange Dana has stock length pinion.
Why would the above quote be incorrect???
Re: 70 Challenger drive shaft length [Re: Zapp] #849491
11/10/10 12:28 PM
11/10/10 12:28 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
One inch would work with the OEM "long" slip yoke, although every stocker I've ever seen has been more like 1/4" to the back of the seal's boot. If using an aftermarket short yoke, be very careful, 1" would be too much for sure.
Rick
Re: 70 Challenger drive shaft length [Re: Ply72rr] #849492
11/10/10 12:30 PM
11/10/10 12:30 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
driveshaft lengths
Wish this list included 7 1/4" measurements...
Re: 70 Challenger drive shaft length [Re: Mapandjlp] #849493
11/10/10 03:35 PM
11/10/10 03:35 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: 70 Challenger drive shaft length [Re: Zapp] #849494
11/10/10 04:38 PM
11/10/10 04:38 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have one that I ran in my Challenger with a 727 and Dana. Car went 9.3's at 3500 lbs. Let me know.
James
Re: 70 Challenger drive shaft length [Re: Rick_Ehrenberg] #849495
11/10/10 08:21 PM
11/10/10 08:21 PM
BDW Offline
BDW  Offline
Rick
So what's the difference in length between the factory part and the "short" yoke?
Re: 70 Challenger drive shaft length [Re: TheOtherDodge] #849496
11/11/10 05:27 AM
11/11/10 05:27 AM
Z
Zapp Offline OP
Zapp  Offline OP
Z
Thanks but that Chart doent cover Hemi 727 lengths which is what I need. Shouldn't matter but I am leaning toward Carbon Fibre.
Re: 70 Challenger drive shaft length [Re: Zapp] #849497
11/11/10 08:45 AM
11/11/10 08:45 AM
BDW Offline
BDW  Offline
Re: 70 Challenger drive shaft length [Re: Zapp] #849498
11/15/10 11:31 PM
11/15/10 11:31 PM
Snoopy Offline
Snoopy  Offline
From the factory 70-71 parts book.
Challenger - 44.60" ctr-ctr 3 1/4" Dia.
