70 Challenger drive shaft length
#849482
11/09/10 10:51 AM
11/09/10 10:51 AM
Posts: 71 Northern Territory, Australia
Zapp
Sorry if this is covered somewhere I couldnt find it.
I need all lengths necessary to order a driveshaft for my Challenger. I have Hemi, 727 and Strange Dana that Im having Cass build soon.
Thanks for any help even if its to say look here idiot..............and a link
Re: 70 Challenger drive shat length
[Re: Zapp]
#849483
11/09/10 11:06 AM
11/09/10 11:06 AM
Posts: 2,648 GA
Boosted
GA
I asked this same question and the result was that I need to buy a yoke.. slip it in the trans to where there is about 3/4 to 1" out and measure center of joint to the center of the joint on the rear-end to get a true shaft..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 70 Challenger drive shaft length
[Re: Zapp]
#849485
11/09/10 12:32 PM
11/09/10 12:32 PM
Posts: 553 DE
Ply72rr
DE
[Re: Boosted]
#849488
11/10/10 03:05 AM
11/10/10 03:05 AM
Posts: 277 Southwest, Mi.
74Cuda
Southwest, Mi.
This 1" rule works great, Just make sure the the car is sitting on the wheels or the rear axle is on jack stands before you measure it.
[Re: BDW]
#849490
11/10/10 10:36 AM
11/10/10 10:36 AM
Zapp
If your motor is located in the stock position, the stock length driveshaft will work.
They didn't custom build each part.
That is what i was thinking, Im using Schumacher mounts and will confirm with Cass that the Strange Dana has stock length pinion.
Why would the above quote be incorrect???
[Re: Rick_Ehrenberg]
#849495
11/10/10 08:21 PM
11/10/10 08:21 PM
Posts: 4,732 Florida
BDW
One inch would work with the OEM "long" slip yoke, although every stocker I've ever seen has been more like 1/4" to the back of the seal's boot. If using an aftermarket short yoke, be very careful, 1" would be too much for sure.
Rick
So what's the difference in length between the factory part and the "short" yoke?
[Re: Zapp]
#849497
11/11/10 08:45 AM
11/11/10 08:45 AM
BDW
