timing issue #840447
10/27/10 08:18 PM
10/27/10 08:18 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
What's the best way to dial in the timing I should set? I have a 440 stroked to 500 cubes, around 14:1 compression. Been running 34deg. Looking to make some adjustments and wondering if I should try 36 without detonation? Any experience or insight on this would be helpful.
Re: timing issue [Re: Big_Fish] #840448
10/27/10 08:21 PM
10/27/10 08:21 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
What fuel you run? I would think 2 degrees in either direction would not hurt. Up the timing until MPH starts to fall off then you are to far.
Re: timing issue [Re: Big_Fish] #840449
10/27/10 08:30 PM
10/27/10 08:30 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
At 14:1 this is clearly not a pump gas engine street engine. That being the case I would probably elect to simply run a locked advance. Just to be safe and assuming that you won't be tuning it on a dyno I would start at 30* and run at least two runs at this setting. Bump it 2* and make two more runs. Repeat this until trap speed starts to fall off. Needless to say it's important to keep all other variables [ launch and shift rpms etc. ] the same. If running alky you could start at 32* If on gas I would start slightly rich on the A/F mixture. Good luck.
Re: timing issue [Re: 5spdcuda] #840450
10/27/10 11:01 PM
10/27/10 11:01 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
put good gas in it and give it a twist.
Re: timing issue [Re: 5spdcuda] #840451
10/27/10 11:12 PM
10/27/10 11:12 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Run 112 fuel. Thank you for the guidance. Seems to run a tad rich. Wondering if bumping up 2deg will help. I'll try 2 passes change it and make 2 more shifting the same.
Re: timing issue [Re: Big_Fish] #840452
10/27/10 11:48 PM
10/27/10 11:48 PM
Renton Washington
Triple Threat Offline
Renton Washington
112 sounds a bit low to me for the much compression. Anyone else think the same?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: timing issue [Re: Big_Fish] #840453
10/28/10 10:13 PM
10/28/10 10:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
I dyno tested a B1-BS headed 452 C.I. 440 motor several years back that had 14.7 to 1 comp. ratio, it liked the VP C14+ versus there C12 race gas. Around 25 HP more with C14+ What heat range and brand spark plug are you using now?
Re: timing issue [Re: Cab_Burge] #840454
10/29/10 01:34 AM
10/29/10 01:34 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
NGK, coldest plug they make.
Re: timing issue [Re: Big_Fish] #840455
10/29/10 02:23 AM
10/29/10 02:23 AM
Gasoline or alcohol?
