Re: timing issue
[Re: 5spdcuda]
#840450
10/27/10 11:01 PM
10/27/10 11:01 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
put good gas in it and give it a twist.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: timing issue
[Re: Big_Fish]
#840452
10/27/10 11:48 PM
10/27/10 11:48 PM
Triple Threat
Renton Washington
112 sounds a bit low to me for the much compression. Anyone else think the same?
Re: timing issue
[Re: Big_Fish]
#840453
10/28/10 10:13 PM
10/28/10 10:13 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I dyno tested a B1-BS headed 452 C.I. 440 motor several years back that had 14.7 to 1 comp. ratio, it liked the VP C14+ versus there C12 race gas. Around 25 HP more with C14+ What heat range and brand spark plug are you using now?
