Re: ECU died again
[Re: dg_dodge]
#833119
10/18/10 08:44 PM
10/18/10 08:44 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have read the same information about the orange box. Seems that you did have better luck with yours. I would go with the chrome box just from the same things you have read. I have a secondary market one presently on mine but will be getting a chrome box and keep the present one as a spare. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: ECU died again
[Re: dg_dodge]
#833120
10/18/10 09:07 PM
10/18/10 09:07 PM
RapidRobert
no gremlins, the newer orange boxes are outsourced & have a fair amt of failures. I would suggest another parts house ECU like the one you bought and for some gain spend your money on a hotter coil/ballast combo for more spark energy as the ECU is pretty much just a on/off switch for the coil pri current like the old breaker points were . If not then the MP chrome or talk to Don @FBO
Re: ECU died again
[Re: dOoC]
#833124
10/18/10 09:35 PM
10/18/10 09:35 PM
RapidRobert
I knew the oranges were made in Mexico (no pond) but I didn't know the MP chrome ones were outsourced now too. Haven't heard of them failing very much though
Re: ECU died again
[Re: dg_dodge]
#833134
10/19/10 03:47 PM
10/19/10 03:47 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Thanks much for the info guys. Both times mine have died, I've only found out when trying to start up (no spark). Is that the way these things go - only find out at startup - or can they die while the motor is running, too?
thats how a lot of electrical parts seem to fail in my experience. they'll get you to where you need to go, but don't count on them getting you back home
Re: ECU died again
[Re: SattyNoCar]
#833135
10/19/10 04:09 PM
10/19/10 04:09 PM
Posts: 4,799 ILL
MLR426
ILL
Just wanted to add, make sure the ECU has a good GROUND. A poor ground will shorten the life of an ECU too. On my drivers, I run one of those braided ground straps from a mounting bolt on the ECU to the engine block.
Is the voltage regulator suppose to be grounded also and not loose to the firewall or does it make any difference ?
logan426
Re: ECU died again
[Re: MLR426]
#833136
10/19/10 04:39 PM
10/19/10 04:39 PM
Posts: 5,445 So Cal
Sinitro
So Cal
logan426
Yes, the voltage regulator must be grounded. Also be sure to sand off the paint on its back side so it is metal-to-metal when titened down...
Just my $0.02...
