ECU died again #833118
10/18/10 08:28 PM
10/18/10 08:28 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi Guys,
It looks like the ECU box has died again on my 1970 Challenger (this one lasted about 9 months). Previously, I had the Mopar Orange box, which lasted about 5 years and died in Jan of this year without any warning. To get the car back home that time, I went to the nearest parts store and bought what they had in stock, which was a cheap looking blue one (less than $30).
So, my first question for the electrical experts out there is - Is this normal to have an ECU go out so soon? Could there be a gremlin lurking somewhere in my system or are these units just kinda crappy? The day it failed I was just out for a drive and got home and turned off the ignition and that was the last time I could get spark out of it.
Secondly, I need to buy a new ECU. I've read some bad stories about the Orange boxes and my experience with the low end replacement wasn't good either. Should I get a chrome box or just try another Orange one?
Thanks a lot for any help or tips!
Re: ECU died again [Re: dg_dodge] #833119
10/18/10 08:44 PM
10/18/10 08:44 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have read the same information about the orange box. Seems that you did have better luck with yours. I would go with the chrome box just from the same things you have read.
I have a secondary market one presently on mine but will be getting a chrome box and keep the present one as a spare.
Craig
Re: ECU died again [Re: dg_dodge] #833120
10/18/10 09:07 PM
10/18/10 09:07 PM
no gremlins, the newer orange boxes are outsourced & have a fair amt of failures. I would suggest another parts house ECU like the one you bought and for some gain spend your money on a hotter coil/ballast combo for more spark energy as the ECU is pretty much just a on/off switch for the coil pri current like the old breaker points were . If not then the MP chrome or talk to Don @FBO
Re: ECU died again [Re: RapidRobert] #833121
10/18/10 09:17 PM
10/18/10 09:17 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
I agree with Rapid Robert. Give Don at HBO a call, he will tell you more than you ever wanted to know about the ecus. Basically, both the orange and chrome units are Chinese junk.
Re: ECU died again [Re: Mike H] #833122
10/18/10 09:21 PM
10/18/10 09:21 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks a lot guys for the info. Anyone have the contact info for Don? I've been off the forum for awhile so might have missed any postings of his.
Re: ECU died again [Re: dg_dodge] #833123
10/18/10 09:28 PM
10/18/10 09:28 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
When did the orange and chrome boxes start coming from across-the-pond ?
Re: ECU died again [Re: dOc !] #833124
10/18/10 09:35 PM
10/18/10 09:35 PM
I knew the oranges were made in Mexico (no pond) but I didn't know the MP chrome ones were outsourced now too. Haven't heard of them failing very much though
Re: ECU died again [Re: RapidRobert] #833125
10/18/10 09:41 PM
10/18/10 09:41 PM
Florida STAYcation
Florida STAYcation
The ORANGES have been made in Mexico always ? ... I got some of the first "kits" Mopar put together and I don't remember any import stickers on them.
Re: ECU died again [Re: dOc !] #833126
10/18/10 10:52 PM
10/18/10 10:52 PM
I think just lately (not sure how long though)
Re: ECU died again [Re: dg_dodge] #833127
10/19/10 07:09 AM
10/19/10 07:09 AM
FRANCE, Paris
Chal340 Offline
Chal340  Offline
FRANCE, Paris
70 Challenger, A66, 340 ci
Re: ECU died again [Re: dg_dodge] #833128
10/19/10 08:15 AM
10/19/10 08:15 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Just wanted to add, make sure the ECU has a good GROUND. A poor ground will shorten the life of an ECU too. On my drivers, I run one of those braided ground straps from a mounting bolt on the ECU to the engine block.
John
Re: ECU died again [Re: SattyNoCar] #833129
10/19/10 08:26 AM
10/19/10 08:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno I lucky I guess I have yet to have an issue w/ a mopar orange box. Check you grounds and check your voltage across the system. Sorry about the problems they sux!
Coming soon!!!!
Re: ECU died again [Re: Mr.Yuck] #833130
10/19/10 10:13 AM
10/19/10 10:13 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I had my orange box for 13 years then I decided to put a higher amp alternator on then Whamo!
It killed it in 5 mins. Funny thing is it would start right up after cooling down for 10 mins. then it would quite again 30 seconds later. Go figure?
Re: ECU died again [Re: superbeedave] #833131
10/19/10 11:46 AM
10/19/10 11:46 AM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks much for the info guys. Both times mine have died, I've only found out when trying to start up (no spark). Is that the way these things go - only find out at startup - or can they die while the motor is running, too?
Re: ECU died again [Re: dg_dodge] #833132
10/19/10 12:19 PM
10/19/10 12:19 PM
P
Paul_Fancsali Offline
P
Get a stock factory 4 post off a late 80's Dodge truck. I have had very little trouble with a factory box not the MP box.
Re: ECU died again [Re: Paul_Fancsali] #833133
10/19/10 03:44 PM
10/19/10 03:44 PM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Rick has some nice ones for sale in the a body parts section, American made
Re: ECU died again [Re: dg_dodge] #833134
10/19/10 03:47 PM
10/19/10 03:47 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
thats how a lot of electrical parts seem to fail in my experience. they'll get you to where you need to go, but don't count on them getting you back home
Re: ECU died again [Re: SattyNoCar] #833135
10/19/10 04:09 PM
10/19/10 04:09 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Is the voltage regulator suppose to be grounded also and not loose to the firewall or does it make any difference ?
logan426
Re: ECU died again [Re: MLR426] #833136
10/19/10 04:39 PM
10/19/10 04:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
logan426
Yes, the voltage regulator must be grounded. Also be sure to sand off the paint on its back side so it is metal-to-metal when titened down...
Just my $0.02...
Re: ECU died again [Re: dg_dodge] #833137
10/19/10 08:03 PM
10/19/10 08:03 PM
the ones I've had go bad started misfiring on multiple cyls as soon as I started it up & had to gun it to limp it home & people thinking their hearing gunfire or firecrackers
