B vs A body Cal tracks #830035
10/14/10 11:15 PM
10/14/10 11:15 PM
Finally a HUSKER again
Moparnut426 Offline OP
So are the B body cal tracs a lot different than the A bodie. i know the front segment is i think longet, but will the rear of the spring, and the front bar work on my demon. I have a set laying around and am wondering.
Kasey
Re: B vs A body Cal tracks [Re: Moparnut426] #830036
10/15/10 12:03 AM
10/15/10 12:03 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
No.
The force bar is shorter on the A's by 2". Same as the front segment length difference.
If you are talking about the mono springs. I have no knowledge of them as I never used them. Best to call travis and ask.
Re: B vs A body Cal tracks [Re: RobX4406] #830037
10/15/10 12:17 AM
10/15/10 12:17 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
FYI, im going to be going to a set of 69 camaro springs and caltrac bars because both front and rear segments are longer. It is a true advantage in a leaf spring car!!
Re: B vs A body Cal tracks [Re: joshking440] #830038
10/15/10 12:23 AM
10/15/10 12:23 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
is a camaro and nova the same length in the front
changes the instant center of the car using more levrage to plant the tires down
1.39 9.85 - 137 mph
Re: B vs A body Cal tracks [Re: Ari440] #830039
10/15/10 05:31 AM
10/15/10 05:31 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why is a longer leaf spring a advantage?
Re: B vs A body Cal tracks [Re: joshking440] #830040
10/15/10 04:47 PM
10/15/10 04:47 PM
Toronto
mshred Offline
mshred  Offline
Toronto
can you give us more info on this? i just bought caltracs and installed them but never heard of this
Re: B vs A body Cal tracks [Re: mshred] #830041
10/15/10 04:56 PM
10/15/10 04:56 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
It helps with leverage and for some reason is helps with axle wrap more than the shorter a-body design. This is another Mopar guys idea, im really just coping him.....
Re: B vs A body Cal tracks [Re: joshking440] #830042
10/20/10 05:20 PM
10/20/10 05:20 PM
@ the shop
E
E-85 408 DART Offline
E
@ the shop
has anybody talked with calvert about this ?? The theory sounds good . but does it work ??? Anybody useing the longer springs have any pics/feedback??
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: B vs A body Cal tracks [Re: E-85 408 DART] #830043
10/20/10 08:07 PM
10/20/10 08:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
1st-gen Camaros/Firebirds & '68-'74 Novas, Omegas, Apollos & Venturas use the same suspension design; 2nd-gen Camaros & Firebirds ditto for '75-up Nova & etc. In GM lingo, Camaro & Firebird are F-bodies, Nova & etc X bodies.
I can see the longer bar having more leverage, but the longer front spring segment would seem to be more prone to flex at the same thickness/arch as a shorter one. It would be interesting to see what John Calvert has to say.
Re: B vs A body Cal tracks [Re: joshking440] #830044
10/20/10 09:56 PM
10/20/10 09:56 PM
OH, USA
Torred Offline
Torred  Offline
OH, USA
I asked about using the 20” front segments with extended and offset hangers on my EBody and Travis said that a 22” front segment would be better. Being that the car would have less body separation, wind-up or something like that.
Re: B vs A body Cal tracks [Re: joshking440] #830045
10/20/10 11:44 PM
10/20/10 11:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Gotta call ya on this one, unless you know more than Chassis guru Dave Morgan
Why would you put inferior leaf springs on your Mopar.
Mopar put way more effort and technology in there leaf spring design.
Dave Morgan in his Chassis manual quote
only leaf springs worth mentioning was design by Chrysler
Re: B vs A body Cal tracks [Re: Bob_Coomer] #830046
10/20/10 11:53 PM
10/20/10 11:53 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
You know that caltrac setups use an aftermarket mono-leaf spring right? Not the factory leaf..
Re: B vs A body Cal tracks [Re: Pat7272] #830047
10/21/10 12:12 AM
10/21/10 12:12 AM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
This would also be a good idea for me in hindsight, my caltrac'd car with drag radials rub the front of the wheelwells on big bumps, I'd love to have the wheel a bit further back... This is due to my bigger tire and nothing to do with caltracs but I'd like the clearance...
If bolting in a mono from a camaro and calvert will provide the right size bar it sounds like a trick setup for those wanting to run bigger tires as well...
Re: B vs A body Cal tracks [Re: Bob_Coomer] #830048
10/21/10 12:23 AM
10/21/10 12:23 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
your not calling me on anything.... I know that the only changed made to a particular car was what I mentioned above and it 60' better then it ever had in its life and ran it the 7's for the first time. It is also the only difference in rear suspensions between an a-body and some brand x stuff which has historically been faster on leaf springs then any other mopar on the planet. I dont know who dave morgan is, but I would liek to know what year that book was written
Re: B vs A body Cal tracks [Re: Bob_Coomer] #830049
10/21/10 12:25 AM
10/21/10 12:25 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Hate to tell you this but there is not a fast radial car in the world on a super stock spring buddy
Re: B vs A body Cal tracks [Re: Torred] #830050
10/21/10 12:30 AM
10/21/10 12:30 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
How does a leaf spring know what kind of car it is in? So by this reasoning a "A body" with cal-tracs has some kind of ill effects?
Re: B vs A body Cal tracks [Re: joshking440] #830051
10/21/10 12:46 AM
10/21/10 12:46 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
OK
what ever, i disagree totally that Chevy has a better leaf spring design......buddy
You actually made me laugh, asking who Dave Morgan is, are you being serious???
No really?
It doesnt matter to me what you do your car. But I might have just held off telling other people to try it..
I have run Cal tracks, on about every body style in the Mopar family, including Mopar pickup trucks..
They work. plain and simple, no need to change leaf springs, or design that was my point
Sounds like a a bunch of trouble, and in the end you still have leaf springs under the car.
Dave Morgan wrote the Chassis Handbook, the bible of suspension tuning and theories. He travels this Country making a living by speaking about chassis tuning, and his classes are always Sold Out.
http://www.davemorganseminars.com/default.asp
Re: B vs A body Cal tracks [Re: scatpacktom] #830052
10/21/10 12:52 AM
10/21/10 12:52 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The front segment is a diff length. From the center of the axle to the front hanger is diff then, so this would then require a diff length torsion tube. (the tube that connects the front segment piviot point/bracket to the spring perch shock bracket)
Re: B vs A body Cal tracks [Re: Bob_Coomer] #830053
10/21/10 12:54 AM
10/21/10 12:54 AM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
I disagree totally that Chevy has a better leaf spring design......buddy
You're not understanding - the only difference between the Caltracs for Mopars vs the caltracs for chevys is their length.
Nobody is talking about putting chevy leafs on a mopar. We're talking about putting chevy LENGTH caltracs (longer) on a mopar.
Re: B vs A body Cal tracks [Re: Bob_Coomer] #830054
10/21/10 01:03 AM
10/21/10 01:03 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I had the 20" (A body???) originally with my SS springs when I went to mono spring Cal said to go 22 inch front segment and was going to sell me the tube/bar by itself but I sold those cal tracs to a friend with ss springs and just bought new 22 cal trac system.
