440 Source Fabricated Aluminum Oil Pan
#827521
10/11/10 08:34 PM
10/11/10 08:34 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
I am pulling my 383 this weekend to paint the engine compartment and while it is out I am looking at replacing the oil pan. I am considering the Fabricated aluminum oil pan from 440 Source and was wondering if anyone is using one and what they think of it ? Thanks, Mark
1969 Super Bee High School car I got back
2004 Ram 2500
Re: 440 Source Fabricated Aluminum Oil Pan
[Re: runnerrt]
#827523
10/11/10 10:48 PM
10/11/10 10:48 PM
Posts: 5,444 So Cal
Sinitro
So Cal
A friend building a 520 stroker went through 2 of these, the welding is low quality.. I would suggest to spend the extra $ & buy a Milodon.... Just my $0.02...
[Re: PC-CHARGER]
#827525
10/12/10 12:15 AM
10/12/10 12:15 AM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
I have one on my engine. It's not bad but a few things to watch for. First, the drain plug is metric thread so be sure to ask and order the correct one. Secondly, I had to enlarge the 4 holes at the front and back of the pan in order to get it on. I have a stud kit for the pan so I couldn't even get it on until I enlarged those eight holes. Last of all, the baffling is marginal. Other than that, it hasn't leaked yet. For the money, it's not too bad but I'd probably look at a different one next time.
Pretty much the way I see it, except, I would stick with the source pan. I have bottomed the pan out once too many times and finally cracked one of the welds. However, minus the MINOR alignment issues, a very solid pan! For the money, I would stick with this pan. If you don't have a drag link to deal with then step up to a Charlies pan. Other than that, this pan gets the job done and looks great. The sump is just as low as the Milodon, so no change there.
Steve
[Re: cl440]
#827529
10/13/10 10:36 PM
10/13/10 10:36 PM
runnerrt
Lakewood, Colorado
Thanks for the info. Not sure which one I am going to use but it does give me somthing to think about.
2004 Ram 2500
[Re: cl440]
#827530
10/13/10 10:38 PM
10/13/10 10:38 PM
Challenger 1
Cincinnati, Ohio
We had the same issues with Milodon pans!
Owned a bunch of Moroso pans over the years and none of them ever leaked.
[Re: DaytonaTurbo]
#827531
10/13/10 10:43 PM
10/13/10 10:43 PM
I don't have their fabricated pan, I have their regular deep sump pan. No issues.
Same here.
I haven't fired the motor yet but pressurized the oiling system with a priming tool and no leaks. Bolted on perfectly and welds all look good.
#827532
10/13/10 10:51 PM
10/13/10 10:51 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I have the 440Source Fab alum pan and love it. The thick pan rail distorts a little from all the welding, just elongate a few of the holes and it's ready to bolt on. I use the Superformance oil pan gaskets with a windage tray, no sealer and no leaks. You can't find a nice fab alum pan anywhere else for 150 bucks.
[Re: SCATPACK 1]
#827534
10/13/10 11:51 PM
10/13/10 11:51 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
are the demensions the same as the milodon? mine has JB Weld on it to stop the leaks.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
