440 Source Fabricated Aluminum Oil Pan #827521
10/11/10 08:34 PM
10/11/10 08:34 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
I am pulling my 383 this weekend to paint the engine compartment and while it is out I am looking at replacing the oil pan. I am considering the Fabricated aluminum oil pan from 440 Source and was wondering if anyone is using one and what they think of it ? Thanks, Mark
1969 Super Bee High School car I got back 2004 Ram 2500
Re: 440 Source Fabricated Aluminum Oil Pan [Re: runnerrt] #827522
10/11/10 09:26 PM
10/11/10 09:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I read on here that one guy said his leaked.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: runnerrt] #827523
10/11/10 10:48 PM
10/11/10 10:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A friend building a 520 stroker went through 2 of these, the welding is low quality..
I would suggest to spend the extra $ & buy a Milodon....
Just my $0.02...
Re: 440 Source Fabricated Aluminum Oil Pan [Re: runnerrt] #827524
10/11/10 10:50 PM
10/11/10 10:50 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I have one on my engine. It's not bad but a few things to watch for. First, the drain plug is metric thread so be sure to ask and order the correct one. Secondly, I had to enlarge the 4 holes at the front and back of the pan in order to get it on. I have a stud kit for the pan so I couldn't even get it on until I enlarged those eight holes. Last of all, the baffling is marginal. Other than that, it hasn't leaked yet. For the money, it's not too bad but I'd probably look at a different one next time.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: PC-CHARGER] #827525
10/12/10 12:15 AM
10/12/10 12:15 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Pretty much the way I see it, except, I would stick with the source pan. I have bottomed the pan out once too many times and finally cracked one of the welds. However, minus the MINOR alignment issues, a very solid pan! For the money, I would stick with this pan. If you don't have a drag link to deal with then step up to a Charlies pan. Other than that, this pan gets the job done and looks great. The sump is just as low as the Milodon, so no change there.
Steve
Re: 440 Source Fabricated Aluminum Oil Pan [Re: Plumcrazyracing] #827526
10/12/10 01:28 AM
10/12/10 01:28 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
just my but my Milodon pan leaked they replaced it and #2 leaks also.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: 70blackfish] #827527
10/12/10 01:35 AM
10/12/10 01:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't have their fabricated pan, I have their regular deep sump pan. No issues.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: 70blackfish] #827528
10/12/10 09:22 AM
10/12/10 09:22 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We had the same issues with Milodon pans!
Re: 440 Source Fabricated Aluminum Oil Pan [Re: cl440] #827529
10/13/10 10:36 PM
10/13/10 10:36 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Thanks for the info. Not sure which one I am going to use but it does give me somthing to think about.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: cl440] #827530
10/13/10 10:38 PM
10/13/10 10:38 PM
Cincinnati, Ohio
Cincinnati, Ohio
Owned a bunch of Moroso pans over the years and none of them ever leaked.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: DaytonaTurbo] #827531
10/13/10 10:43 PM
10/13/10 10:43 PM
Same here.
I haven't fired the motor yet but pressurized the oiling system with a priming tool and no leaks. Bolted on perfectly and welds all look good.
Re: 440 Source Fabricated Aluminum Oil Pan #827532
10/13/10 10:51 PM
10/13/10 10:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have the 440Source Fab alum pan and love it. The thick pan rail distorts a little from all the welding, just elongate a few of the holes and it's ready to bolt on. I use the Superformance oil pan gaskets with a windage tray, no sealer and no leaks. You can't find a nice fab alum pan anywhere else for 150 bucks.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: Challenger 1] #827533
10/13/10 11:22 PM
10/13/10 11:22 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Back in the 70's, I had a Sox & Martin Super Stock pan with the Side Kick out. It split on the rear side at a welded seam. Just saying it could happen to anyones pan if it was built out of thin alum to keep it light. Had it re welded and no other problems.
I looked at one of Brandons pans at a show and it looked really good. I would buy one if I was in the market for one.
Old Geezer Racing
Re: 440 Source Fabricated Aluminum Oil Pan [Re: SCATPACK 1] #827534
10/13/10 11:51 PM
10/13/10 11:51 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
are the demensions the same as the milodon? mine has JB Weld on it to stop the leaks.
Re: 440 Source Fabricated Aluminum Oil Pan [Re: runnerrt] #827535
10/14/10 01:52 AM
10/14/10 01:52 AM
AndyF Offline
AndyF  Offline
I have an extra one if you're interested. Never used it except in some pictures. I'm pretty sure I also have the pickup for it.
