Took the 605 to the dyno......
#803145
09/16/10 04:00 PM
09/16/10 04:00 PM
Posts: 549 Chicagoland
chargerron69
Chicagoland
Took the engine to Rhyne Competition Engines in Gary IN. Very nice place and Matt is a great guy. Got it there Tuesday, they got right on it and hooked it up. Went this morning to see some pulls and it was definately worth every cent. i was really excited to have this experience. Ill post the sheets later when i can get them scanned to the comp. and go into detail on the runs. In the mean time lets hear some guesses on what you think it made. here are the specs
605ci Callies 4.75 stroke crank Oliver billet rods JE custom 10.72 compression gas ported pistons Mopar mega block 4.503 bore Indy 572-13 heads ported and flowed by mike radnis and bob mendez. T&D rocker arms on individual shafts. Smith Bros pushrods Straitline perf. roller cam 280/292 @ .050 .735/.723 on 112 lsa Crower Roller lifters that are rebuildable unlike most others. Milodon gear drive Milodon dual line oil system and pan. Indy valve covers with oiling inside Indy 440-3X intake ported throughout Pro Systems dominator carb with spec sheet. Cometic MLS head gaskets MSD Pro Billet distributor Taylor 10mm wires ATI Superdampener ARP hardware throughout, everything is studded but the intake custom set of headers 2.125 to 2.25 step with 4 inch collectors
oh yea....and i got video!
Re: Took the 605 to the dyno......
[Re: chargerron69]
#803146
09/16/10 05:03 PM
09/16/10 05:03 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Compression is kind of low. No specs on the cam. Gas or alcohol carb?
Pretty similar to my 540 other than Crank stroke and -13 heads vs my -1's. I have 13.8 compression.
875 hp?
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#803147
09/16/10 05:15 PM
09/16/10 05:15 PM
chargerron69
Chicagoland
added cam spec, its gas , its 1206 cfm
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger
same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!!
72 Newport 2 door 400 727
85 Ram 440 4 speed O/D 3.54 dana
[Re: chargerron69]
#803157
09/16/10 09:21 PM
09/16/10 09:21 PM
Posts: 90 Chandler, AZ
cirrusaero
Chandler, AZ
Looking forward to seeing what this pulls.......... and the video
68 Charger 605 Hemi, Keisler 5spd, Pro-touring 66 Coronet 2dr post 66 Satellite
[Re: chargerron69]
#803158
09/16/10 10:12 PM
09/16/10 10:12 PM
Posts: 509 duluth,mn
psycomopar
duluth,mn
i would like to know for sure i have one at shop right know . touch but different b1 heads and cam specs are bigger.and about 15 t0 1. i know i am really curious to see what mine makes i have thought about taming the combo down before finishing though. i guess about 925hp 870tq
[Re: MegaDart]
#803160
09/16/10 10:29 PM
09/16/10 10:29 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
I hope it made A LOT!! My 604ci made 1156hp and 856ftlb. 4.5" stroke 4.62 bore BBC. Single cast four barrel intake with 1150 dominator
Pretty sure that engine isn't with the 572-13 heads.
My guess is 912hp 845torque
Re: Took the 605 to the dyno......UPDATE!
[Re: chargerron69]
#803164
09/17/10 03:27 AM
09/17/10 03:27 AM
Posts: 43,307 Bend,OR USA
Cab_Burge
Are the oil and water temps correct or are they transposed on the data tracking?
