Took the 605 to the dyno...... #803145
09/16/10 04:00 PM
09/16/10 04:00 PM
Chicagoland
chargerron69 Offline OP
Chicagoland
Took the engine to Rhyne Competition Engines in Gary IN. Very nice place and Matt is a great guy.
Got it there Tuesday, they got right on it and hooked it up. Went this morning to see some pulls and it was definately worth every cent. i was really excited to have this experience. Ill post the sheets later when i can get them scanned to the comp. and go into detail on the runs. In the mean time lets hear some guesses on what you think it made. here are the specs
605ci
Callies 4.75 stroke crank
Oliver billet rods
JE custom 10.72 compression gas ported pistons
Mopar mega block 4.503 bore
Indy 572-13 heads ported and flowed by mike radnis and bob mendez.
T&D rocker arms on individual shafts.
Smith Bros pushrods
Straitline perf. roller cam 280/292 @ .050 .735/.723 on 112 lsa
Crower Roller lifters that are rebuildable unlike most others.
Milodon gear drive
Milodon dual line oil system and pan.
Indy valve covers with oiling inside
Indy 440-3X intake ported throughout
Pro Systems dominator carb with spec sheet.
Cometic MLS head gaskets
MSD Pro Billet distributor
Taylor 10mm wires
ATI Superdampener
ARP hardware throughout, everything is studded but the intake
custom set of headers 2.125 to 2.25 step with 4 inch collectors
oh yea....and i got video!
Re: Took the 605 to the dyno...... [Re: chargerron69] #803146
09/16/10 05:03 PM
09/16/10 05:03 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Compression is kind of low.
No specs on the cam.
Gas or alcohol carb?
Pretty similar to my 540 other than Crank stroke and -13 heads vs my -1's. I have 13.8 compression.
875 hp?
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Took the 605 to the dyno...... [Re: nhramark] #803147
09/16/10 05:15 PM
09/16/10 05:15 PM
Chicagoland
Chicagoland
added cam spec, its gas , its 1206 cfm
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Took the 605 to the dyno...... [Re: chargerron69] #803148
09/16/10 05:39 PM
09/16/10 05:39 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
That'll be a stump puller! I'd guess 870 TQ and 890 HP.
Re: Took the 605 to the dyno...... [Re: chargerron69] #803149
09/16/10 05:45 PM
09/16/10 05:45 PM
Denmark
Dart of Denmark Offline
Denmark
925hp
Re: Took the 605 to the dyno...... [Re: Dart of Denmark] #803150
09/16/10 06:01 PM
09/16/10 06:01 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
825 HP and 810 Tourque
Re: Took the 605 to the dyno...... [Re: camastomcat] #803151
09/16/10 06:10 PM
09/16/10 06:10 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
so what are the numbers.
67' charger 499 RB 10.57 at 127
Re: Took the 605 to the dyno...... [Re: dragram440] #803152
09/16/10 07:41 PM
09/16/10 07:41 PM
SD USA
neonic Offline
neonic  Offline
SD USA
This sounds like it will probably be a spray motor?
Re: Took the 605 to the dyno...... [Re: neonic] #803153
09/16/10 07:52 PM
09/16/10 07:52 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I hope it made A LOT!!
My 604ci made 1156hp and 856ftlb. 4.5" stroke 4.62 bore BBC. Single cast four barrel intake with 1150 dominator
Re: Took the 605 to the dyno...... [Re: MegaDart] #803154
09/16/10 07:58 PM
09/16/10 07:58 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I'm sure yours was a touch over 10.7 sgueeze with a bit bigger heads.
This is an odd combo, definitely pump gas friendly. The bigger heads and good bottom end parts lead me to think you will be giving it a bit of the hose.
NA 825 HP/800 ft/lbs.
Re: Took the 605 to the dyno...... [Re: Bigcube] #803155
09/16/10 08:02 PM
09/16/10 08:02 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Is this the one that was for sale?
851/821
Re: Took the 605 to the dyno...... [Re: abodiesonly1] #803156
09/16/10 09:19 PM
09/16/10 09:19 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
900hp-800tq
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Took the 605 to the dyno...... [Re: chargerron69] #803157
09/16/10 09:21 PM
09/16/10 09:21 PM
Chandler, AZ
cirrusaero Offline
cirrusaero  Offline
Chandler, AZ
Looking forward to seeing what this pulls.......... and the video
68 Charger 605 Hemi, Keisler 5spd, Pro-touring
66 Coronet 2dr post
66 Satellite
Re: Took the 605 to the dyno...... [Re: chargerron69] #803158
09/16/10 10:12 PM
09/16/10 10:12 PM
duluth,mn
P
psycomopar Offline
psycomopar  Offline
P
duluth,mn
i would like to know for sure i have one at shop right know . touch but different b1 heads and cam specs are bigger.and about 15 t0 1. i know i am really curious to see what mine makes i have thought about taming the combo down before finishing though. i guess about 925hp 870tq
Re: Took the 605 to the dyno...... [Re: cirrusaero] #803159
09/16/10 10:14 PM
09/16/10 10:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
raised cam block?
Re: Took the 605 to the dyno...... [Re: MegaDart] #803160
09/16/10 10:29 PM
09/16/10 10:29 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Pretty sure that engine isn't with the 572-13 heads.
My guess is 912hp 845torque
Re: Took the 605 to the dyno......UPDATE! [Re: Diablo] #803161
09/17/10 12:08 AM
09/17/10 12:08 AM
Chicagoland
Chicagoland
here it is guys! wish it was little higher compression but is what it is, and its more than i thought it was, and has a really smooth power curve! special thanks to Bob Mendez! you built another mighty mopar motor!
http://www.youtube.com/watch?v=HCy61dQ79R4
Re: Took the 605 to the dyno......UPDATE! [Re: chargerron69] #803162
09/17/10 12:18 AM
09/17/10 12:18 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice street motor for sure!
Re: Took the 605 to the dyno......UPDATE! [Re: chargerron69] #803163
09/17/10 02:08 AM
09/17/10 02:08 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I was way off on the TQ, but pretty close on the HP. Congrats those are good numbers for that combo!
Re: Took the 605 to the dyno......UPDATE! [Re: chargerron69] #803164
09/17/10 03:27 AM
09/17/10 03:27 AM
Cab_Burge Online work
Cab_Burge  Online Work
Are the oil and water temps correct or are they transposed on the data tracking?
