6.1 to 5.7 hemi #798075
09/10/10 05:01 PM
09/10/10 05:01 PM
Canada
shadowauto Offline OP
Canada
I need to know if a 6.1 Hemi intake with throtle body will fit on a 5.7 Hemi thanks Francis.
Re: 6.1 to 5.7 hemi [Re: shadowauto] #798076
09/10/10 05:19 PM
09/10/10 05:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Bolt pattern is the same, so bolting it on is the easy part.
Unfortunately that's where the easy stuff ends. There's a big port mismatch with any head older than 2009, and there isn't much room for the throttle body and intake hoses if a truck timing cover is used. There are modified truck timing covers available on some of the forums out there if a person wanted to go that route.
It would be better to swap 6.1 heads on at the same time as the intake, and use it with a passenger car timing cover...And if swapping 6.1 heads on to a 2005 and older 5.7, why not swap 6.1 valve covers and the better 6.1 coils on at the same time?
Rich H.
Esse Quam Videri
Re: 6.1 to 5.7 hemi [Re: ZIPPY] #798077
09/10/10 05:34 PM
09/10/10 05:34 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
...and a 6.1 short block
2017 Grand Cherokee Overland
Re: 6.1 to 5.7 hemi [Re: patrick] #798078
09/10/10 05:42 PM
09/10/10 05:42 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
...and the 6.1 exhaust manifolds are better too
Rich H.
Esse Quam Videri
Re: 6.1 to 5.7 hemi [Re: ZIPPY] #798079
09/10/10 05:47 PM
09/10/10 05:47 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Here is a pic of one that has been modified. I have done it . It gets a little thin on the sides.
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: 6.1 to 5.7 hemi [Re: gdemon] #798080
09/10/10 10:32 PM
09/10/10 10:32 PM
Canada
Canada
My motor is a 2009 vvt belive to be a truck engine with oil pick up in the back my intention was to go with a mod 6 pack but no body make a system to make it run I may go with factory fuel injected any sugestion thanks
Re: 6.1 to 5.7 hemi [Re: shadowauto] #798081
09/11/10 12:15 AM
09/11/10 12:15 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Try Imagine Injection out of Phoenix...
http://www.imagineinjection.com/
JB Rhinehart, Realist
A-Body's RULE!
Re: 6.1 to 5.7 hemi [Re: shadowauto] #798082
09/11/10 08:39 AM
09/11/10 08:39 AM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
since this is a 09 engine it has the Eagle heads they have the 6.1 size ports
Re: 6.1 to 5.7 hemi [Re: mopardad] #798083
09/11/10 08:47 PM
09/11/10 08:47 PM
Canada
Canada
that mean i can use a intake with throtle body off a 6.1 with tti heather any year 6.1 or 09 up thanks.
