Re: 6.1 to 5.7 hemi
[Re: shadowauto]
#798076
09/10/10 05:19 PM
09/10/10 05:19 PM
Posts: 17,852 S.E. Michigan
ZIPPY
S.E. Michigan
Bolt pattern is the same, so bolting it on is the easy part.
Unfortunately that's where the easy stuff ends. There's a big port mismatch with any head older than 2009, and there isn't much room for the throttle body and intake hoses if a truck timing cover is used. There are modified truck timing covers available on some of the forums out there if a person wanted to go that route.
It would be better to swap 6.1 heads on at the same time as the intake, and use it with a passenger car timing cover...And if swapping 6.1 heads on to a 2005 and older 5.7, why not swap 6.1 valve covers and the better 6.1 coils on at the same time?
Rich H.
Esse Quam Videri
Re: 6.1 to 5.7 hemi
[Re: ZIPPY]
#798077
09/10/10 05:34 PM
09/10/10 05:34 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
...and a 6.1 short block
Re: 6.1 to 5.7 hemi
[Re: ZIPPY]
#798079
09/10/10 05:47 PM
09/10/10 05:47 PM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
Here is a pic of one that has been modified. I have done it . It gets a little thin on the sides.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
Re: 6.1 to 5.7 hemi
[Re: shadowauto]
#798082
09/11/10 08:39 AM
09/11/10 08:39 AM
Posts: 1,510 Manheim PA.
mopardad
Manheim PA.
My motor is a 2009 vvt belive to be a truck engine with oil pick up in the back my intention was to go with a mod 6 pack but no body make a system to make it run I may go with factory fuel injected any sugestion thanks
since this is a 09 engine it has the Eagle heads they have the 6.1 size ports
