Power Steering pumps How many styles made & where 2 get
#791658
09/03/10 01:22 PM
09/03/10 01:22 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Ok having problems with a 68 charger. The customer put a 440 in it that I think came out of a 73 truck. He used the pump that came on the motor when he got it. He had a mechanic shop put a seal kit in it. It started leaking again and he at 1st thought it was the new steering sector we got for the car. I got him a replacement one and him and another guy put it in. I took a look at it and said it wasn't the sector that itwas the seal on the pump. We tried getting 2 from a local parts house and both have been wrong. They took the old one and are trying to figure out that way.
My question is how many different types of pumps did chrysler use? Where else can a guy find a good one? Not looking for a numbers correct just one that works! Also I know this but someone told the customer that you can use ATF in power steering systems. I told him yeah in new cars but not in old cars. What is the real reason to that? Is the ATF too strong for the seals? He seen that the other shop has red fluid in there and then someone said yeah you can use ATF so they did.
thanks corey
Contact Me about AMD Prices
Re: Power Steering pumps on 440's where to get?
[Re: Finoke]
#791661
09/03/10 03:43 PM
09/03/10 03:43 PM
hotairballoonpilot
South Dakota
Thanks guys. Local place said they can get a reman out of the twin cities by tuesday. They 1st said there was only one but now with this new one coming that makes 3 that they have found. So really how many styles did chrysler make?
[Re: scratchnfotraction]
#791663
09/03/10 05:59 PM
09/03/10 05:59 PM
hotairballoonpilot
South Dakota
Yeah thats what dad said to and he has been working at the same Chrysler dealershipfor the last 45 years as a mechanic. Said that there was just one style that he ever remembers.
[Re: hotairballoonpilot]
#791664
09/03/10 06:02 PM
09/03/10 06:02 PM
Posts: 7,664 IN
ahy
IN
There was Saginaw, Federal and one other type. Best advice I can give is matchup the pictures of yours and the reman so you get one that fits your brackets.
Re: Power Steering pumps How many styles made & where 2 get
[Re: gtx6970]
#791669
09/03/10 06:11 PM
09/03/10 06:11 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Differences between TRW and Federal pumps Federal pump has a tapped hole in the end of the pump shaft. TRW/Thompson pump has a hex-shaped hole or no hole in the end of the pump shaft. Federal pump uses a reservoir cap with "ears" much like a radiator cap. TRW/Thompson pump uses a reservoir cap that is round and may have vertical serrations but no "ears". NOTE: Federal pump reservoir cap will fit on a TRW/Thompson pump.
[Re: gtx6970]
#791670
09/03/10 06:19 PM
09/03/10 06:19 PM
Posts: 15,487 Florida
scratchnfotraction
mine looks like the saginaw with out the brackets in the first pics thanks for the skoolin on them,this is my first BB truck build so it a little of a learning curve on the BB bolt ons thanks
#791671
09/04/10 11:38 AM
09/04/10 11:38 AM
hotairballoonpilot
South Dakota
Thanks! I think we found the correct one. Will know more on tuesday when it shows up. The pics helped ALOT! tHANKS!THANKS!
COREY
