Power Steering pumps How many styles made & where 2 get #791658
09/03/10 01:22 PM
09/03/10 01:22 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Ok having problems with a 68 charger. The customer put a 440 in it that I think came out of a 73 truck. He used the pump that came on the motor when he got it. He had a mechanic shop put a seal kit in it. It started leaking again and he at 1st thought it was the new steering sector we got for the car. I got him a replacement one and him and another guy put it in. I took a look at it and said it wasn't the sector that itwas the seal on the pump. We tried getting 2 from a local parts house and both have been wrong. They took the old one and are trying to figure out that way.
My question is how many different types of pumps did chrysler use? Where else can a guy find a good one? Not looking for a numbers correct just one that works! Also I know this but someone told the customer that you can use ATF in power steering systems. I told him yeah in new cars but not in old cars. What is the real reason to that? Is the ATF too strong for the seals? He seen that the other shop has red fluid in there and then someone said yeah you can use ATF so they did.
thanks
corey
Contact Me about AMD Prices
Re: Power Steering pumps on 440's where to get? [Re: hotairballoonpilot] #791659
09/03/10 02:43 PM
09/03/10 02:43 PM
IN
ahy Offline
ahy  Offline
IN
I had my pump rebuilt by Firm Feel. A little expensive but it has worked great. Your local autoparts store can probably get you a reman pump in a couple days also.
Muscle era cars tolerate ATF as power steering fluid. It was sometimes recommended or approved. The friction modifiers added to ATF to help the clutches in a transmission apparantly are not helpful to the power steering system however.
Power steering fluid is better... plus readily available at parts stores Walmart ect. and not too expensive so it is preferred for older cars.
Some newer cars absolutly will not tolerate the wrong fluid. My '98 Neon works beautifully with MOPAR fluid. With anything else it screeches and squeals for 5-10 min after starting.
Some of the newest cars use synthetic ATF+4 as power steering fluid so you just have to check the owners manual.
Re: Power Steering pumps on 440's where to get? [Re: ahy] #791660
09/03/10 02:47 PM
09/03/10 02:47 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I think 440 source has them and the pulleys.
Re: Power Steering pumps on 440's where to get? [Re: Finoke] #791661
09/03/10 03:43 PM
09/03/10 03:43 PM
South Dakota
South Dakota
Thanks guys. Local place said they can get a reman out of the twin cities by tuesday. They 1st said there was only one but now with this new one coming that makes 3 that they have found. So really how many styles did chrysler make?
Re: Power Steering pumps on 440's where to get? [Re: hotairballoonpilot] #791662
09/03/10 05:19 PM
09/03/10 05:19 PM
scratchnfotraction Offline
I have one from a 78 440 MH on the shelf
same looking pump as the sb one i have,just diff brackets
Re: Power Steering pumps on 440's where to get? [Re: scratchnfotraction] #791663
09/03/10 05:59 PM
09/03/10 05:59 PM
South Dakota
South Dakota
Yeah thats what dad said to and he has been working at the same Chrysler dealershipfor the last 45 years as a mechanic. Said that there was just one style that he ever remembers.
Re: Power Steering pumps on 440's where to get? [Re: hotairballoonpilot] #791664
09/03/10 06:02 PM
09/03/10 06:02 PM
IN
ahy Offline
ahy  Offline
IN
There was Saginaw, Federal and one other type. Best advice I can give is matchup the pictures of yours and the reman so you get one that fits your brackets.
Re: Power Steering pumps on 440's where to get? [Re: hotairballoonpilot] #791665
09/03/10 06:05 PM
09/03/10 06:05 PM
I take a closer look at the sb one and the BB one I have
IIRC the lines are diff on them...at least the BB one at the box anyways
one reason I swaped to the manual steering on my 440 truck build
needed to have pressure line and return fabed up to hook to the box with the MH BB pump
as far as I know its either a federal pump..or saginaw pump on BB,IIRC they used both
Re: Power Steering pumps How many styles made & where 2 get [Re: hotairballoonpilot] #791666
09/03/10 06:06 PM
09/03/10 06:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Saginaw with R/RB brackets
Re: Power Steering pumps How many styles made & where 2 get [Re: gtx6970] #791667
09/03/10 06:08 PM
09/03/10 06:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
TRW pump with B/Rb brackets
Re: Power Steering pumps How many styles made & where 2 get [Re: gtx6970] #791668
09/03/10 06:10 PM
09/03/10 06:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Federal pump with Hemi B/Rb brackets
Re: Power Steering pumps How many styles made & where 2 get [Re: gtx6970] #791669
09/03/10 06:11 PM
09/03/10 06:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Differences between TRW and Federal pumps
Federal pump has a tapped hole in the end of the pump shaft.
TRW/Thompson pump has a hex-shaped hole or no hole in the end of the pump shaft.
Federal pump uses a reservoir cap with "ears" much like a radiator cap.
TRW/Thompson pump uses a reservoir cap that is round and may have vertical serrations but no "ears".
NOTE: Federal pump reservoir cap will fit on a TRW/Thompson pump.
Re: Power Steering pumps How many styles made & where 2 get [Re: gtx6970] #791670
09/03/10 06:19 PM
09/03/10 06:19 PM
mine looks like the saginaw with out the brackets in the first pics
thanks for the skoolin on them,this is my first BB truck build
so it a little of a learning curve on the BB bolt ons
thanks
Re: Power Steering pumps How many styles made & where 2 get [Re: scratchnfotraction] #791671
09/04/10 11:38 AM
09/04/10 11:38 AM
South Dakota
South Dakota
Thanks! I think we found the correct one. Will know more on tuesday when it shows up. The pics helped ALOT! tHANKS!THANKS!
COREY
Re: Power Steering pumps How many styles made & where 2 get [Re: hotairballoonpilot] #791672
09/05/10 01:35 AM
09/05/10 01:35 AM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
Hey GTX6970, looks like you got a lot of info on these. Does it look like I have the brackets going right in my 65 New Yorker? Thanks- Pat
