SHOW ME YOUR ASPENS!!!!! #756309
07/23/10 11:42 PM
07/23/10 11:42 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Im really liking these cars!!!! Combo and times would be great too.
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756310
07/24/10 10:35 AM
07/24/10 10:35 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Before the crash...
Dont want to show aftermath or look at it myself.
Re: SHOW ME YOUR ASPENS!!!!! [Re: theclutcher] #756311
07/24/10 10:57 AM
07/24/10 10:57 AM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
It's a 423ci small block based off a 340 R Block bored .040 over, oil mods done by RyanJ, Pro-Gram billet caps 1-4, and has a K1 crank and rods. The rods are 6.200 long and the crank stroke is 4.125. It has custom CP pistons to produce a 13.5:1 compression with Total Seal Max Seal rings. The heads are INDY 360-2 CNC ported and polished by RyanJ that flow 325/250. The intake is a MP M-1 single plane converted to a Dominator flange and ported by RyanJ as well. The cam is a bullet solid roller with 276/280 duration at .050 with .696/.712 lift with a 1.6 ratio rocker and ground on a 109. The carb is a Big's 1050 Dominator Stage 7. I'm using the T&D rocker setup and Smith Brothers .116 wall 5/16 pushrods. I have the lifter bores bushed because I'm oiling through the pushrod. I have the Charlie's 8 quart pan with a Milodon pickup and a Sealed Power HV oil pump. I'm running TTI 1-7/8" headers as well. I'm using a MSD Digital 6 Plus box with a MSD HVC II Coil and a MSD Pro Billet Distributor. I race at 600 feet above see level and use 110 octane Sunoco fuel.
3430lb. Race Ready F-Body (with me)
Ford 9" with a 4.56 gear
CRT Super Pro II 727 trans with brake
29.5x10.5x15 M/T ET Drag
Skinnies on front
5400 stall 8" PTC converter
Solid K-Frame Bushings
Subframe connectors
Engine torque strap
6-Point cage
Caltracs with their monoleafs and Rancho 9000's
3" full exhaust with Dynomax Oval Ultra Flo's
This combo has ran a best of 10.25 @ 132.77 mph
Re: SHOW ME YOUR ASPENS!!!!! [Re: 1976 Aspen] #756312
07/24/10 11:01 AM
07/24/10 11:01 AM
How about a side view???
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756313
07/24/10 11:31 AM
07/24/10 11:31 AM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
Full cage, 14x32s, 4 Link dana, struts - rack and pinion front, Mild pump gas Hyd cam 440, Powerglide with T-brake, shiftnoid, delay Box
Used to go 10s, now de-tuned to run super consistant mid 11s
Easy low maint. Super Pro car, but I have been too busy to even have it out this year, I may decide to race it at the Mopar Nats. with a For Sale sign in the window
Re: SHOW ME YOUR ASPENS!!!!! [Re: Dr-Dave2] #756314
07/25/10 11:15 PM
07/25/10 11:15 PM
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756315
07/25/10 11:31 PM
07/25/10 11:31 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
http://mopardragracing.ning.com/video/gran-fury-at-columbus-chrysler there is a video of mine not really that good of a video but u can hear how nice it sounds. runs 13.0's mostly should be faster, with A 360 in it but full interior, exhaust, taged and titled..
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: SHOW ME YOUR ASPENS!!!!! [Re: kissmyaspen] #756316
07/25/10 11:36 PM
07/25/10 11:36 PM
Your right,It DOES sound good!!!!!
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756317
07/26/10 12:20 PM
07/26/10 12:20 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
I just wish it was little faster than it was. but i like them because u dont see many of them at the track..
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756318
07/26/10 04:21 PM
07/26/10 04:21 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
Here is my sons, 408 W2 Ryan J roller cam, ported heads 904/999 w/low gearset,8 3/4,SS springs, best 60'1.37 Best time to date 9.94 MPH I'm not sure of but think it was 136
Re: SHOW ME YOUR ASPENS!!!!! [Re: mopardad] #756319
07/26/10 09:05 PM
07/26/10 09:05 PM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
Here's mine its a 78 with a 440 MCH stage 2 cnc'd eddy rpms a .630/.650 solid lift 10.75 comp m1 intake with some work a 10in tci 3500 stall 950hp carb 2in tti headers and 3in ext weights close to 3700lbs with me in it best et is 11.05 @ 122 and 8 3/4 with 4.10s and a spool. Pump gas and street driven
75 duster 440 in the works
71 pro street cuda
Re: SHOW ME YOUR ASPENS!!!!! [Re: MIKES_DUSTER] #756320
07/26/10 09:09 PM
07/26/10 09:09 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
Re: SHOW ME YOUR ASPENS!!!!! [Re: plasticfantastic] #756321
07/26/10 09:14 PM
07/26/10 09:14 PM
Charlotte NC
cudadave72 Offline
cudadave72  Offline
Charlotte NC
I'd like to see that Aspen go 9 seconds!!!
Re: SHOW ME YOUR ASPENS!!!!! [Re: 1fastaspen] #756322
07/26/10 09:22 PM
07/26/10 09:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Interesting comparison. My blown 340 Volare,3850lbs. Street trim best 11.01@122. Iron heads,240@.050 cam,2"headmans,7.8-1,4.30 8 3/4
w/posi. I've driven it a couple of times from Detroit to the Nats in Columbus.
Doug
Re: SHOW ME YOUR ASPENS!!!!! [Re: dvw] #756323
07/26/10 09:42 PM
07/26/10 09:42 PM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
Nice car I seen it at the cc at martin this year me and dad we standing at the fence talking to you.the blower really sets it off
71 pro street cuda
Re: SHOW ME YOUR ASPENS!!!!! [Re: 1fastaspen] #756324
07/26/10 11:01 PM
07/26/10 11:01 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Just a std. stroker with 2 stage spray, switched to a crt pro race auto, time will tell
Re: SHOW ME YOUR ASPENS!!!!! [Re: quick77rt ] #756325
07/26/10 11:17 PM
07/26/10 11:17 PM
Sweet video!!!! Nice car!!!!
