Re: Really HIGH-WINDING B/RB engine ... ? [Re: MR_P_BODY] #717179
06/05/10 10:33 PM
06/05/10 10:33 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
No reason it can't be done, I think a destroked 383 crank to ~3.2" with a 2.200 journal and a long 7.100 rod in A 4.375" BORE 400 BLOCK would be a very reliable high-revving bottom head. The pistons would have about a 1.16" CH and could probably be in the 2000-2100G bobweight range.
The question is...how much are you willing to spend for valvetrain? You'll want a solid roller with good TD or Jessel valvetrain, milled pedestals with Race W2 Style billet blocks, and you're definatly going to want very high quality lightweight valves an edurance road race style lobe and beehive race springs.
I would shoot for an 8200-ish peak power and a 8000-9K limit, that's doable with Typical Max Wedge aluminum head flowing ~380cfm....you can go even higher with a B1 style head but you might as well put in a formula 1 style tack because that combo of parts won't fall out of a tree below about 4000rpm!
Let me know when you build it, I've toyed with a high rev B motor combo for years but I couldn't think of a suitable lightweight body to put it in.....although I toyed with dropping one in a Cobra replica
WIZE
In Car:
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Streetwize] #717180
06/05/10 11:56 PM
06/05/10 11:56 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I asked this question a while back concerning my 451 Pro-comp head build. After getting bashed for using Chinese cylinder heads and questioned about my quest for RPM we collectively decided my idea was stupid. The application was for my stripped out '66 Charger that is getting converted into a corner carver street car. I'd still undecided on what I am going to do.
One thing is for sure though...if you want big RPM in a B/RB motor you will need a Jesel valve train, ugly valve spring pressures and a very expensive oiling system to make it live. I'm sure you or I could put together a mathematically correct high revving big block and get lucky enough to have it live but what if it didn't? Lots of money down the drain.
I'd love to build an all aluminum Jesel equipped dry sump big block with some heads that flowed >400 cfm however I'm not sure that is the best bang for the buck. A pump gas 572 is starting to sound like the hot ticket...
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717181
06/06/10 01:44 AM
06/06/10 01:44 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
CB .... my thoughts on all this ...is this.
"ALL I want is a boat that will GATE SHOT like a bear."
You want a torque motor with torque pitch 3 or 4 blade prop. They dont slip, they hook.
You dont want a RPM motor with a 2 blade speed prop that cavitates on take off and then hooks and books after a soft take off.
Any B/RB motor will have plenty of torque for you IMO, just prop it accordingly.
For a Lake boat I dont think I would ever try to make a rev motor for a Gate Shot boat.
IMO, some props can hook better in water then our slicks can on pavement. mike
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Sport440] #717182
06/06/10 12:51 PM
06/06/10 12:51 PM
I had a IMP Aztec V I/O that had a 14x14 three bladed aluminum prop originally with a 300 C.I. buick V8. I ened up trading a car for it after it had a 350 Chevy installed in it. This was a family boat, not a race boat. I ended up trying four different pitches on two different props, both where the same diameter, style and amount of blades. Going down to 12 pitch made the boat a real dog on take off, the motor would cavitate the prop and it would take forever tp plane I had the original prop repitch to 16 and ended up buying the 18 pitch prop for it, that boat like more pitch, take off was less dramaitic, it planed quicker and faster and top speed went up for the same RPM It was a deep V 21 ft that was heavy, light is right and the bottom of the boat condition and design it way more important than the motor power Buy a race boat if you want to play with the race boys
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Cab_Burge] #717183
06/06/10 06:06 PM
06/06/10 06:06 PM
Florida STAYcation
dUmB! Offline OP
The village idiot's idiot
dUmB!  Offline OP
Florida STAYcation
Hey Guyz ...THX to all for food-for-thought. I guess the prob here ... is that I am just-not in most of yours mind-set when it comes to a power-plant.
B1 heads, Jesel valve-train, 572 cubic inches ? .... wasssupy ??? ... LOTS of the stuff I bought for this boat - and the boat itself - I got on eBay ...
The rotating assembly that I was thinking about using before ...30 over 383 old-school TRW's on rods with a crank AND a set of 452 heads WITH a set of adjustable iron Crane rockers ...I got ON eBay for 55$ ....
HEY ...I know a GOOD MOTOR is going to cost TONS more than this ... but the way things look now ....I am probably going to have to owner-finance the property I have here in order to SELL IT and THEN put down 200-LARGE on some property in FL.
So I gotsta-bee a bit of a cheap-skate here !
Now to CB's quote .... RACE BOYZ ?
Any of you ever been to Key West .... and their SuperBoat races ? .... the boats, babes and BIG-BUCKS would blow yerr mind. I have been there many times ..... and even though most of the stuff is Chebby-powered .. it even-now - gives me goose-bumps thinking about watching those races from on-the-rocks at Fort-Zack state park .... as the FOUR ENGINED boats would go flying by ....30 feet away going 160 mph .... launching off 4 to 6 foot rollers ...
IF you can ever get the opportunity to see it ....do it.
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717184
06/06/10 11:35 PM
06/06/10 11:35 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
High-revving and "old-school" TRW's don't seem to go hand-in-hand to me! Aren't they REAL heavy?
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Labratt] #717185
06/07/10 12:28 AM
06/07/10 12:28 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you want screaming RPM, does it have to be a big block? Why not pick up one of the R5P7 motors that are already setup for high rpm screaming? S/F.....Ken M
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Labratt] #717186
06/07/10 12:28 AM
06/07/10 12:28 AM
Florida STAYcation
dUmB! Offline OP
dUmB!  Offline OP
Florida STAYcation
I hear-you on being "heavy" ... that was the reason for this topic. But me thimks I was uNcorrect in my thinking about needing such a high-rpm motor... I thought there was a TON of "slip" at lower speeds.
So ... these TRW's ...with a say a 557 or 590 cam ....should be good for SPURTS of what ?? ....
..... 7800 ?
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717187
06/07/10 12:37 AM
06/07/10 12:37 AM
..... 7800 ?
be lucky to get 5800 out of it in a boat.
Re: Really HIGH-WINDING B/RB engine ... ? #717188
06/07/10 02:15 AM
06/07/10 02:15 AM
Florida STAYcation
dUmB! Offline OP
dUmB!  Offline OP
Florida STAYcation
ONLY 5800 ? ..... such a Silly Boy !!
...But WHY would you be thinking that I would ONLY be running on the small-PRIMARIES of the ...... ThermoQuad ? ...
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717189
06/07/10 06:07 AM
06/07/10 06:07 AM
oh, i forgot about you and your thermocrack carbs. in that case make it 5400 rpm max in a boat.
as a boy, you must have wanted to be a plumber when you grew up and your still having pipe dreams.
Re: Really HIGH-WINDING B/RB engine ... ? #717190
06/07/10 10:36 AM
06/07/10 10:36 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Not trying to further dump on you here than others have already...........
but for all the extra $$ need to run rpm's........
I'd change out that old obsolete gearbox and get a splitcase Casale to run a low rpm RB (440-500 c.i.).
It's hard to widen an rpm band more than anyone else has yet in history. Developing the "cake and eat it too" set-up means lots of trial and error gear and prop testing.
Engine wear goes up exponentially with rpm.
As FL states famous Big Daddy used to say, "it's better to dial back and win consistently than to run out on the ragged edge and break often".
Re: Really HIGH-WINDING B/RB engine ... ? #717191
06/07/10 01:15 PM
06/07/10 01:15 PM
Florida STAYcation
dUmB! Offline OP
dUmB!  Offline OP
Florida STAYcation
You FORGOT about that ? ...
HAVING another "senior" moment ...huh ? ...
But seriously ...why would you think that those old-school RACE forged pistons have an rpm limit of LESS THAN a OEM factory cast flat-top piston ? ....and WHAT ABOUT a boat would be any diff than in a car?
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Dean_Kuzluzski] #717192
06/07/10 01:36 PM
06/07/10 01:36 PM
Florida STAYcation
dUmB! Offline OP
dUmB!  Offline OP
Florida STAYcation
Why HI ....DeanOsaur !
People DUMPING on me ? .. I don't see-that at all ....'cept maybe DPO ...and in most cases there .. he is just having a "seasoned-citizen" MOMENT(s) !!
The v-drive box ? ...I wish I had a Casale ... do you know anyone who has one? ... I have been in-touch with Johnsons Speed Whse in Lansing and they said that Dick Lahaie was an expert on V-drives. Do YOU know anything about the "box" I have?
ALL HERE considered so far ... I think that I should just put-together what I have. About all I will be needing is a cam ..... 520 to 600 lift range .... solid lifter ... with a WICKED idle !!
....and it also has to get 20-miles-per-gallon ! (and THIS IS at 'choo ...DPO)
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717193
06/07/10 02:08 PM
06/07/10 02:08 PM
Holly/MI
Holly/MI
Hey Doc!
I just don't see the reason to go high RPM HP when we all know BIG torque moves mass. Physics don't lie.
Just build what you got and go from there. Why try to reinvent the wheel.
Me, no specific knowledge about the "Thorobred" brand of v-drive gearbox. I did pick up an old "Hemi" gearbox (it stands for Harrington Engineering Manufacturing Industries) for a low-$$ sweet deal at a swapmeet a few years ago. This thing is about 1/3rd larger than the more common splitcase Casale. It looks like it will handle brutal loads of torque & HP. A 500 c.i. wedge with a set of Indy's would work fine for me.
Re: Really HIGH-WINDING B/RB engine ... ? [Re: Dean_Kuzluzski] #717194
06/07/10 05:18 PM
06/07/10 05:18 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Doc,
I can tell you from personal experience. '71 Sanger shovel nose ski hydro, maybe a little lighter than your Stevens, but not much. Pretty decent lake boat with a .060 over ex-NASCAR Hemi with alky Hilborns, ran 121 quarters at mid-10.20's around 8400 with 22% gears and I think (its been 30 years) 11 1/4 by 16 Menkens prop. For grins between rebuilds I threw a .030 over 383 together, VHS prepped 906 NASCAR heads, 540" Erson Mushroom with 850 on a Tarantula (Torker?)manifold, nothing exotic, just decent parts. Motor sounded plenty healthy on the trailer, trying to get it to leave hard was another story. Get up on a plane and it was a sweet little cruiser, just didn't have enough bottom end to get it up quickly. If you want to cruise around the lake and get decent mileage(thats a relative term in a boat), think you could have some fun with a 383. A lot of people mistakenly think a high-winding low torque setup should work in a boat if it works in a car, but that is seldom the case, especially in a direct drive boat. Water just has a way of absorbing torque and HP, and I don't understand the physics, just know from experience that it does. My
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Really HIGH-WINDING B/RB engine ... ? [Re: 23T Hemmee] #717195
06/07/10 06:04 PM
06/07/10 06:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If you want to turn 9k in a boat and hit it hard outa the hole its hard to beat a 2 stroke
Re: Really HIGH-WINDING B/RB engine ... ? #717196
06/07/10 10:02 PM
06/07/10 10:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I was wondering when someone would finally say it. And he's not talking about piston weight, I think he is say your missing something important - torque and horsepower.
Re: Really HIGH-WINDING B/RB engine ... ? [Re: BSB67] #717197
06/08/10 07:44 PM
06/08/10 07:44 PM
Florida STAYcation
dUmB! Offline OP
dUmB!  Offline OP
Florida STAYcation
Hey guy THX for the additional input ..... I am at the 'brary right now(with that Xcellent 'net connection) ... got to go in a bit .... come-on-back with more to digest !
Re: Really HIGH-WINDING B/RB engine ... ? [Re: dUmB!] #717198
06/10/10 09:52 AM
06/10/10 09:52 AM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
If you are not just totally hung up on putting a mopar engine in it the why not swap in a Duramax diesel? You can get a complete used one for $2500 - $3500 & a simple programer alone will get somewhere between 550-600 hp with around 900 lb ft. Get a properly geared box to take advantage of the torque & 3800 rpm power band & you are set. Just food for thought but budget & power sort of go hand in hand with a diesel.
