Re: .040 Over and .020 under on a 383... is this smart?
[Re: RapidRobert]
#70696
06/10/08 11:39 AM
06/10/08 11:39 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The key is a comination of machining and piston choice. Going .040 over is nothing in a stock stroke engine. Those that say otherwise are new at this game. .020 on the crank is not a huge deal either, unless you are planning to really hammer on it in a heavy car. Get decent pistons, and have the block milled to 0 deck for whatever you buy. A warning, that may take a bit of milling...lol They now make B wedge drop in stroker kits too, but, without sonic testing the block, I wouldnt go that route. I know some stout 383s that out run poorly engineered RB strokers. Sometimes it doesnt pay to spend.
[Re: moper]
#70697
06/10/08 12:40 PM
06/10/08 12:40 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MoparforLife]
#70698
06/10/08 04:19 PM
06/10/08 04:19 PM
Posts: 217 NJ
z1bigtom
NJ
Just ordered my pistons for my 383... L2315F .040 Block will be zero deck...People have been telling me .030 has to come off but to get the CR it has to be done... My crank is .010/.010 Oh yea and i'm goin from a .030 bore to a .040 so mine can be plate honed ![](/ubbthreads/images/graemlins/beer.gif)
78 D200 Clubcab, 400, 727, Dana 60 welded...Droped 3" front..Rear soon to come
[Re: redmist]
#70700
06/10/08 04:47 PM
06/10/08 04:47 PM
They mains on mopars are bigger than most Chevys so turning them under size isnt the deal. Reheat treating them is expensive and not that many places do it. But I've built 3 451 strokers using stock 440 cranks all were in the 600+ HP range . One of the nice parts of the 440 crank in the 383/400 block is that you cut down the counter weights to clear the block. This takes almost 4 lbs off the crank. With Eagle rods(I know Chinese) or other after market rods and Diamond pistons the bob weight comes down to under that of a stock 340. How about 451 cube small block that revs good. I havent bored to many 383s but most early engines till 68 or 69 were fairly heavy casting so .040 is no problem. My old 413 could be bored .070 over. I know a guy that sonic tested a 67 318 truck block he was able to over bore to 340 diameter with no problems .I believe that is .100. 400s though are thinner casting. At .040 I would pour the block with block fill to support the this walls. Good parts fit better and are cheaper in the long run. Kits are ussualy cheap for a reason. And its not because they want to do you a favor. ![](/ubbthreads/images/graemlins/smoke.gif)
[Re: frank]
#70702
06/10/08 05:51 PM
06/10/08 05:51 PM
Posts: 175 jonesboro, ark
ramcharger82
jonesboro, ark
my 360 is .060 over and no probs. been beating it up for 3 yrs now.
Built not Bought
[Re: z1bigtom]
#70706
06/10/08 09:16 PM
06/10/08 09:16 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
i only had totake .018 off to get zero ...
YMMV
Yea i guess it needs to be assembled up and measured..Pistons will be in this week so i will know soon..
take one piston and rod combo and move it to the 4 corners of the block , pic the number at a corner and tell the shop where and how much , whe nthey square it all 4 corners should be the same .
i had an extra 383 rod so i had my local shop hone the small end so i could get the pin in without pressing anything as i was waiting for the rods i was actually going to run to arrive from florida , but you could just have your pistons put on your reconed rods and just pick one to use ...
