.040 Over and .020 under on a 383... is this smart? #70689
06/09/08 10:54 PM
06/09/08 10:54 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Long story short, I had a bad set of Crane Rocker adjusters in a set of Gold 1.5 rockers. The adjusters ate themselves away, and the engine lost oil pressure.
I took the engine down tonight and it lokks... errr BAD!
The 1968 Block is already bored .030 over in the piston bores, and the crank is turned .010 under already.
Would it be stupid to go to .040 on the bores and .020 on the crank? I know alot of folks say .030 is max on the bores, and I have no idea on the crank!
If I could save this engine with a rebuild it would be GREAT!
I have a place in my heart for this revin' 383!
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70690
06/09/08 11:09 PM
06/09/08 11:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can turn the crank as far as you need to so long as somebody makes a bearing set for it. I would not worry about that at all.
The machine shop can sonic test the cylinder wall thickness beforehand. I don't know anything about the wall thickness on a typical 383 as far as how big you can go.
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70691
06/09/08 11:19 PM
06/09/08 11:19 PM
You're in goood shape all you need is time & money & it sounds like that is not a problem for you in this case.
Re: .040 Over and .020 under on a 383... is this smart? [Re: RapidRobert] #70692
06/09/08 11:28 PM
06/09/08 11:28 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
I am looking at this kit for my rebuild:
http://store.summitracing.com/partdetail.asp?part=FEM%2DCSMHP738%2D422&view=128&N=700+115
I would like to get higher compression then this kit offers and I would like to use a set of Edelbrock 84cc heads...
Also quench is a factor as well, and I am still learning about that...!
I guess I may be better off specing all the parts myself instead of getting a kit like this.
So many options!
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70693
06/09/08 11:46 PM
06/09/08 11:46 PM
I am a firm believer in quench & I highly suggest you get the correct pistons.
Re: .040 Over and .020 under on a 383... is this smart? [Re: RapidRobert] #70694
06/09/08 11:52 PM
06/09/08 11:52 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Looking around, I guess I could go with a stroker kit from a place like Muscle motors. Or I will have to have a company custom make a set for me...
Good thing I have bunch of parts off the trashed motor!!!
This is going to get expensive!
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70695
06/10/08 12:14 AM
06/10/08 12:14 AM
yes it will. You might contact Andyf here,he would be a good person to talk to for stroker advice.
Re: .040 Over and .020 under on a 383... is this smart? [Re: RapidRobert] #70696
06/10/08 11:39 AM
06/10/08 11:39 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The key is a comination of machining and piston choice. Going .040 over is nothing in a stock stroke engine. Those that say otherwise are new at this game. .020 on the crank is not a huge deal either, unless you are planning to really hammer on it in a heavy car. Get decent pistons, and have the block milled to 0 deck for whatever you buy. A warning, that may take a bit of milling...lol They now make B wedge drop in stroker kits too, but, without sonic testing the block, I wouldnt go that route. I know some stout 383s that out run poorly engineered RB strokers. Sometimes it doesnt pay to spend.
Re: .040 Over and .020 under on a 383... is this smart? [Re: moper] #70697
06/10/08 12:40 PM
06/10/08 12:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: .040 Over and .020 under on a 383... is this smart? [Re: MoparforLife] #70698
06/10/08 04:19 PM
06/10/08 04:19 PM
NJ
z1bigtom Offline
z1bigtom  Offline
NJ
Just ordered my pistons for my 383...
L2315F .040 Block will be zero deck...People have been telling me .030 has to come off but to get the CR it has to be done...
My crank is .010/.010
Oh yea and i'm goin from a .030 bore to a .040 so mine can be plate honed
78 D200 Clubcab, 400, 727, Dana 60 welded...Droped 3" front..Rear soon to come
Re: .040 Over and .020 under on a 383... is this smart? [Re: z1bigtom] #70699
06/10/08 04:28 PM
06/10/08 04:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
i only had totake .018 off to get zero ...
YMMV
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70700
06/10/08 04:47 PM
06/10/08 04:47 PM
They mains on mopars are bigger than most Chevys so turning them under size isnt the deal. Reheat treating them is expensive and not that many places do it. But I've built 3 451 strokers using stock 440 cranks all were in the 600+ HP range . One of the nice parts of the 440 crank in the 383/400 block is that you cut down the counter weights to clear the block. This takes almost 4 lbs off the crank. With Eagle rods(I know Chinese) or other after market rods and Diamond pistons the bob weight comes down to under that of a stock 340. How about 451 cube small block that revs good.
I havent bored to many 383s but most early engines till 68 or 69 were fairly heavy casting so .040 is no problem. My old 413 could be bored .070 over. I know a guy that sonic tested a 67 318 truck block he was able to over bore to 340 diameter with no problems .I believe that is .100. 400s though are thinner casting. At .040 I would pour the block with block fill to support the this walls. Good parts fit better and are cheaper in the long run. Kits are ussualy cheap for a reason. And its not because they want to do you a favor.
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70701
06/10/08 05:21 PM
06/10/08 05:21 PM
tucson az
frank Offline
frank  Offline
tucson az
the 383 in my Charger is .040 over. No problems at all
Re: .040 Over and .020 under on a 383... is this smart? [Re: frank] #70702
06/10/08 05:51 PM
06/10/08 05:51 PM
jonesboro, ark
ramcharger82 Offline
jonesboro, ark
my 360 is .060 over and no probs. been beating it up for 3 yrs now.
Built not Bought
Re: .040 Over and .020 under on a 383... is this smart? [Re: ramcharger82] #70703
06/10/08 06:59 PM
06/10/08 06:59 PM
Upper Midwest
Upper Midwest
In short - I wouldn't think twice about it. Just do it. You won't have a problem.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: .040 Over and .020 under on a 383... is this smart? [Re: redmist] #70704
06/10/08 07:36 PM
06/10/08 07:36 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
About any 383 I know of will go .040 without a problem
Re: .040 Over and .020 under on a 383... is this smart? [Re: JohnRR] #70705
06/10/08 09:08 PM
06/10/08 09:08 PM
NJ
z1bigtom Offline
z1bigtom  Offline
NJ
YMMV
Yea i guess it needs to be assembled up and measured..Pistons will be in this week so i will know soon..
Re: .040 Over and .020 under on a 383... is this smart? [Re: z1bigtom] #70706
06/10/08 09:16 PM
06/10/08 09:16 PM
JohnRR Offline
JohnRR  Offline
YMMV
take one piston and rod combo and move it to the 4 corners of the block , pic the number at a corner and tell the shop where and how much , whe nthey square it all 4 corners should be the same .
i had an extra 383 rod so i had my local shop hone the small end so i could get the pin in without pressing anything as i was waiting for the rods i was actually going to run to arrive from florida , but you could just have your pistons put on your reconed rods and just pick one to use ...
Re: .040 Over and .020 under on a 383... is this smart? [Re: JohnRR] #70707
06/11/08 04:32 PM
06/11/08 04:32 PM
NJ
z1bigtom Offline
z1bigtom  Offline
NJ
YMMV
Great info John thanks...Just got pistons today So its off to the machine shop..
