Page 1 of 10 1 2 3 9 10
Hit the DYNO! Results are IN Now with VIDS #650005
03/24/10 01:23 PM
03/24/10 01:23 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
Looks like Scott has been busy in the last week cuz he called me to tell me we should be ready to make some pulls tomorrow.
I knew we were getting close but I thought we had a little more to do
Here's a recap just to rehresh everyones memory.
72 440 block bored .030 decked so pistons are .010 in the hole
Wiesco Pro Tru pistons 12.05-1 compression
K1 rods
Facotry forged crank turned .010/.010 and balanced.
Cam
Comp cams Magnum series
Duration at .050" Lift 262 int./262 exh
Actual lift using 1.6 intake and 1.5 exh 578 int and 555 exh.
Installed at 108.5*'s
Edelbrock heads
Milled to .064 cc chambers
Hand ported By Scott Koffel
Flow data.....
Lift/int/exh
.100/83.05/69.55
.200/161.46/113.46
.300/230.23/143.98
.400/280.46/178.41
.500/312.75/200.32
.600/317.25/214.40
.700/319.50/222.23
.800/319.50/228.49
Team G intake worked and matched to heads
APD built 950HP alky carb
2 1/8 hooker SC w/ 3.5 collectors
MSD dist W/ Fircore 50's
Hope I didn't leave anything out
Anyone have any thoughts on what it might put out?
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650006
03/24/10 01:41 PM
03/24/10 01:41 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
535.62 HP
669.1 FT LBS
Nice build, glad to see shes getting close!!
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650007
03/24/10 01:45 PM
03/24/10 01:45 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
Sounds like a good combo i wish i was close to the motor phase instead of "the ugly mockup motor" phase Lol! i would guess just under 600 hp
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: Moparnut426] #650008
03/24/10 01:46 PM
03/24/10 01:46 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
never tried to guess before but looks like about 610hp/585tq
good luck,
looks like a nice build to me!
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: Moparnut426] #650009
03/24/10 01:48 PM
03/24/10 01:48 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I am goin 715 @ 7k and 570 torque @ 5300
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: Moparnut426] #650010
03/24/10 02:08 PM
03/24/10 02:08 PM
BROOK PARK, OH
BROOK PARK, OH
535.62 HP
669.1 FT LBS
That's about what my old motor made
Here's the specs on that one
440, .030 over
cast crank
6LY rods
hyper pistons sitting .070 in the hole
CR is 8.6 to 1
OOTB Eddy heads (Intake Valve Diameter (in) 2.140 in. Exhaust Valve Diameter (in) 1.810 in.)
Cam, (solid lift)
Intake Valve Lift with 1.5 Ratio 0.555 in.
Exhaust Valve Lift with 1.5 Ratio 0.555 in.
Duration at 050 inch Lift 262 int./262 exh.
Did NOT degree it in just lined up the dots but..
Lobe Separation (degrees) 110
Intake Centerline: 106
Team G intake
750 BG claw (running 110 oct)
MSD dist locked out @ 38*s
2 1/8 hooker SC headers.
And it's sheet
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: emarine01] #650011
03/24/10 02:09 PM
03/24/10 02:09 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I assume its on alky?
590hp 600tq
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: emarine01] #650012
03/24/10 02:11 PM
03/24/10 02:11 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
579hp
608tq
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650013
03/24/10 02:15 PM
03/24/10 02:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill what was it last time on alky? I assume your
going straight to alky with that carb
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650014
03/24/10 02:38 PM
03/24/10 02:38 PM
organ
maximum entropy Offline
organ
it shall make the power of 5,000 oldsmobile cutlass supremes!
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: MR_P_BODY] #650015
03/24/10 02:38 PM
03/24/10 02:38 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
618 HP
637 TQ
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: StripeHOG] #650016
03/24/10 03:02 PM
03/24/10 03:02 PM
tboomer Offline
tboomer  Offline
595 hp....Less than me...
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: tboomer] #650017
03/24/10 03:06 PM
03/24/10 03:06 PM
632 HP
579 FT.LBS. TORQUE
LOOKS LIKE YOU BE A 10.60 RIDE.
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: tboomer] #650018
03/24/10 03:09 PM
03/24/10 03:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
668 hp and 588 tq
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650019
03/24/10 03:17 PM
03/24/10 03:17 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Bill i am realy excited for you!if you do it later in the day i think i can come out and watch/help.i know you will have plenty of video.668 hp and 588 tq
[668 hp and 588 tq ]
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650020
03/24/10 03:25 PM
03/24/10 03:25 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Plenty of headder for that motor, Bill..maybe alky wants more.
The little old lady from Pasadena is back!
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: Barnstorm] #650021
03/24/10 03:28 PM
03/24/10 03:28 PM
what does the winner get Wild Billy?
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: MR_P_BODY] #650022
03/24/10 03:29 PM
03/24/10 03:29 PM
BROOK PARK, OH
BROOK PARK, OH
After a little tweaking it made 622hp on alky last time.
We'll be using a gas carb to break it in and seat the rings then it's all Booze after that
Mike, my dad is in the same boat. He has to work but I'm hoping he can leave a little early and watch some of the pulls.
I'm sure there will be a few things we need to button up as well as breaking it in.
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? [Re: WILD BILL] #650023
03/24/10 03:39 PM
03/24/10 03:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My junk 906 headed 470 made 614 hp and 598 ft lbs. so I`ll guess 640hp and 580+ tq. Can`t wait to hear the results.
Re: Hitting the DYNO tomorrow ! What's it gonna make now?? #650024
03/24/10 03:41 PM
03/24/10 03:41 PM
BROOK PARK, OH
BROOK PARK, OH
Have to see if I can come up with anything
I could always send ya my old timing chain
