Hit the DYNO! Results are IN Now with VIDS
#650005
03/24/10 01:23 PM
03/24/10 01:23 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Looks like Scott has been busy in the last week cuz he called me to tell me we should be ready to make some pulls tomorrow.
I knew we were getting close but I thought we had a little more to do
Here's a recap just to rehresh everyones memory.
72 440 block bored .030 decked so pistons are .010 in the hole Wiesco Pro Tru pistons 12.05-1 compression K1 rods Facotry forged crank turned .010/.010 and balanced.
Cam Comp cams Magnum series Duration at .050" Lift 262 int./262 exh Actual lift using 1.6 intake and 1.5 exh 578 int and 555 exh. Installed at 108.5*'s
Edelbrock heads Milled to .064 cc chambers Hand ported By Scott Koffel Flow data.....
Lift/int/exh .100/83.05/69.55 .200/161.46/113.46 .300/230.23/143.98 .400/280.46/178.41 .500/312.75/200.32 .600/317.25/214.40 .700/319.50/222.23 .800/319.50/228.49
Team G intake worked and matched to heads
APD built 950HP alky carb
2 1/8 hooker SC w/ 3.5 collectors
MSD dist W/ Fircore 50's
Hope I didn't leave anything out
Anyone have any thoughts on what it might put out?
Re: Hitting the DYNO tomorrow ! What's it gonna make now??
[Re: Moparnut426]
#650008
03/24/10 01:46 PM
03/24/10 01:46 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
never tried to guess before but looks like about 610hp/585tq ? good luck, looks like a nice build to me!
[Re: Moparnut426]
#650010
03/24/10 02:08 PM
03/24/10 02:08 PM
WILD BILL
BROOK PARK, OH
535.62 HP
669.1 FT LBS
Nice build, glad to see shes getting close!!
That's about what my old motor made
Here's the specs on that one
440, .030 over cast crank 6LY rods hyper pistons sitting .070 in the hole CR is 8.6 to 1
OOTB Eddy heads (Intake Valve Diameter (in) 2.140 in. Exhaust Valve Diameter (in) 1.810 in.)
Cam, (solid lift) Intake Valve Lift with 1.5 Ratio 0.555 in. Exhaust Valve Lift with 1.5 Ratio 0.555 in. Duration at 050 inch Lift 262 int./262 exh. Did NOT degree it in just lined up the dots but.. Lobe Separation (degrees) 110 Intake Centerline: 106
Team G intake
750 BG claw (running 110 oct)
MSD dist locked out @ 38*s
2 1/8 hooker SC headers.
And it's sheet
[Re: WILD BILL]
#650014
03/24/10 02:38 PM
03/24/10 02:38 PM
Posts: 5,080 organ
maximum entropy
organ
it shall make the power of 5,000 oldsmobile cutlass supremes!
[Re: tboomer]
#650017
03/24/10 03:06 PM
03/24/10 03:06 PM
632 HP 579 FT.LBS. TORQUE LOOKS LIKE YOU BE A 10.60 RIDE.
[Re: WILD BILL]
#650020
03/24/10 03:25 PM
03/24/10 03:25 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Plenty of headder for that motor, Bill..maybe alky wants more.
The little old lady from Pasadena is back!
[Re: MR_P_BODY]
#650022
03/24/10 03:29 PM
03/24/10 03:29 PM
WILD BILL
BROOK PARK, OH
Bill what was it last time on alky? I assume your going straight to alky with that carb
After a little tweaking it made 622hp on alky last time.
We'll be using a gas carb to break it in and seat the rings then it's all Booze after that
Mike, my dad is in the same boat. He has to work but I'm hoping he can leave a little early and watch some of the pulls.
I'm sure there will be a few things we need to button up as well as breaking it in.
#650024
03/24/10 03:41 PM
03/24/10 03:41 PM
WILD BILL
BROOK PARK, OH
what does the winner get Wild Billy?
Have to see if I can come up with anything
I could always send ya my old timing chain
