Re: Cranking Compression?
[Re: MR_P_BODY]
#641613
03/16/10 07:29 PM
03/16/10 07:29 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I don't understand any of this stuff you all are WORRYING about. If the engine was put together and you KNOW what the static compression is/was/should be,,,you are not going to change that figure with all these 'calculations'. A leak-down test will show you if there is a problem in the valves/rings/headgaskets etc. Why worry and ask questions about your engine? If the leakage is high,,you have a problem in that cylinder.....simple enough I think.
If you like drag racing, support your local track.
[Re: CHAPPER]
#641615
03/16/10 08:12 PM
03/16/10 08:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pretty simple really.... I was going to do a compression test and wanted to know what it should be... thats all, I wanted to do the compression test before I pulled the rockers to do the leak down
[Re: emarine01]
#641617
03/16/10 08:52 PM
03/16/10 08:52 PM
MR_P_BODY
I think once you have your intake closing point close for the calc it should fall with in 10 psi of your gauge reading, the calcs are a little confusing on the duration methods
It came real close once I added the 40* (which I didnt read before)... I guess you need to read the directions...LOL
[Re: mopar dave]
#641620
03/17/10 01:38 AM
03/17/10 01:38 AM
Posts: 4,209 New York
polyspheric
New York
whats the volume to pressure index representing or what does it mean?
That's so kewl! They "borrowed" it from my (copyright-protected) site. It's the DCR times the actual trapped cylinder volume times a .6% correction factor to approximate low speed torque for converter stall purposes,etc.
Boffin Emeritus
