Re: Cranking Compression?
[Re: MR_P_BODY]
#641594
03/16/10 11:20 AM
03/16/10 11:20 AM
Posts: 2,521 PA
moparacer
PA
Wallace has about every calculator you would ever need.
They have a dynamic and effective comp calculator.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#641595
03/16/10 11:28 AM
03/16/10 11:28 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I use the KB site one. It's simple (aside from remembering the negative figure for dome volume/positive deck height) and is within 20psi of my results in most cases.
[Re: mopar dave]
#641597
03/16/10 12:28 PM
03/16/10 12:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well with checking all the different calculators and doing a compression check MAYBE I dont have the compression I thought I had.... I cant believe I was that far off when I checked the measurements when I built it.... it comes up with a 9.5 compression ratio on just about all of them..... I did a leak down and that showed pretty decent, from 2% to 7% ... no wonder I'm not making the power I figure it should
[Re: MR_P_BODY]
#641598
03/16/10 12:34 PM
03/16/10 12:34 PM
Thumperdart
State of confusion
Too many variables..........just test it and you`ll know for sure. My experience shows that big duration cams w/lots of overlap generally show lower numbers for example: my 360 w/a dur. of 255@ .050 cranked bet 190-200 cold. My 470 w/275-280 dur.@.050 cranks bet 170-175 and my buddys low 8-sec chevy small block w/a BIG roller(don`t remember #`s) cranks at 155 or so.
[Re: mopar dave]
#641603
03/16/10 01:54 PM
03/16/10 01:54 PM
MR_P_BODY
Thats the one thing ... I dont have a degree at 0, my cam card only has .050 for the valve timing and my cam is a 276/284
[Re: AndyF]
#641609
03/16/10 04:00 PM
03/16/10 04:00 PM
MR_P_BODY
I don't see how you can work backwards to CR from cranking compression. Put a 16V system on there and the cranking compression will go up due to the faster cranking speed. Pull all the plugs and pull the carb off the intake and the cranking compression will go up a bunch. Do it warm and the cranking compression will go up.
One of the calculators stated it for a 300 crank RPM and I am assuming they do some magic calculations to come up with a number
[Re: MR_P_BODY]
#641610
03/16/10 04:13 PM
03/16/10 04:13 PM
Posts: 15,491 the boonies
aarcuda
the boonies
i used http://www.not2fast.com/turbo/compression/cranking_pressure.shtml for intake opening I only have .050 also. in the instructions it says to add 40 (thats 20 degrees x 2) to the duration at .050 so i did and it came out to 166. my cranking pressure is surprisingly 165
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
