Page 3 of 3 1 2 3
Re: Cranking Compression? [Re: MR_P_BODY] #641613
03/16/10 07:29 PM
03/16/10 07:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I don't understand any of this stuff you all are WORRYING about. If the engine was put together and you KNOW what the static compression is/was/should be,,,you are not going to change that figure with all these 'calculations'. A leak-down test will show you if there is a problem in the valves/rings/headgaskets etc. Why worry and ask questions about your engine? If the leakage is high,,you have a problem in that cylinder.....simple enough I think.
If you like drag racing, support your local track.
Re: Cranking Compression? [Re: cudadon] #641614
03/16/10 08:02 PM
03/16/10 08:02 PM
MR_P_BODY Offline OP
Mike did you cc the block and the chamber? That will tell the truth. Don
Yes I did when I built it
Re: Cranking Compression? [Re: CHAPPER] #641615
03/16/10 08:12 PM
03/16/10 08:12 PM
Pretty simple really.... I was going to do a compression
test and wanted to know what it should be... thats
all, I wanted to do the compression test before I
pulled the rockers to do the leak down
Re: Cranking Compression? [Re: MR_P_BODY] #641616
03/16/10 08:42 PM
03/16/10 08:42 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think once you have your intake closing point close for the calc it should fall with in 10 psi of your gauge reading, the calcs are a little confusing on the duration methods
Re: Cranking Compression? [Re: emarine01] #641617
03/16/10 08:52 PM
03/16/10 08:52 PM
It came real close once I added the 40* (which I didnt
read before)... I guess you need to read the directions...LOL
Re: Cranking Compression? [Re: MR_P_BODY] #641618
03/16/10 09:11 PM
03/16/10 09:11 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
hehehe, when i did it the first time, i didnt read the destructions and came out to something like 300 psig
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Cranking Compression? [Re: cudadon] #641619
03/17/10 12:03 AM
03/17/10 12:03 AM
Missouri
galen Offline
galen  Offline
Missouri
Mike using the calculator on the Not2fast.com site you gave. I punched in 10.20comp.4.150 stroke.6.76 rod. My cam card list duration on intake at 296, or 263 at.050. So I put in 296. 0 alt. 70 degree temp. says I should have 152, Mine runs 155 average cranking. Close if I am right with the duration number.
Re: Cranking Compression? [Re: mopar dave] #641620
03/17/10 01:38 AM
03/17/10 01:38 AM
New York
polyspheric Offline
polyspheric  Offline
New York
whats the volume to pressure index representing or what does it mean?
That's so kewl!
They "borrowed" it from my (copyright-protected) site.
It's the DCR times the actual trapped cylinder volume times a .6% correction factor to approximate low speed torque for converter stall purposes,etc.
Boffin Emeritus
Re: Cranking Compression? [Re: polyspheric] #641621
03/17/10 06:56 AM
03/17/10 06:56 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
i used the not to fast one on my
4.15 crank
6.670 rod
12 to 1 flat top with a .484 mp hyd cam
shows cranking pressure of 200
and when i built it last year with file fit rings it showed 180-185 every cyl
Re: Cranking Compression? [Re: n_bogie1984] #641622
03/17/10 08:17 AM
03/17/10 08:17 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
4.15 crank
6.670 rod
might have 12:1 flat top pistons BUT what is your actual compression ratio? could be much lower than 12:1 if the block wasnt decked, head volume cc'd, too thick of a gasket etc....
Page 3 of 3 1 2 3
