Page 3 of 3 1 2 3
Re: Cranking Compression? [Re: MR_P_BODY] #641613
03/16/10 07:29 PM
03/16/10 07:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I don't understand any of this stuff you all are WORRYING about. If the engine was put together and you KNOW what the static compression is/was/should be,,,you are not going to change that figure with all these 'calculations'. A leak-down test will show you if there is a problem in the valves/rings/headgaskets etc. Why worry and ask questions about your engine? If the leakage is high,,you have a problem in that cylinder.....simple enough I think.
If you like drag racing, support your local track.
Re: Cranking Compression? [Re: cudadon] #641614
03/16/10 08:02 PM
03/16/10 08:02 PM
MR_P_BODY Offline OP
Mike did you cc the block and the chamber? That will tell the truth. Don
Yes I did when I built it
Re: Cranking Compression? [Re: CHAPPER] #641615
03/16/10 08:12 PM
03/16/10 08:12 PM
Pretty simple really.... I was going to do a compression
test and wanted to know what it should be... thats
all, I wanted to do the compression test before I
pulled the rockers to do the leak down
Re: Cranking Compression? [Re: MR_P_BODY] #641616
03/16/10 08:42 PM
03/16/10 08:42 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think once you have your intake closing point close for the calc it should fall with in 10 psi of your gauge reading, the calcs are a little confusing on the duration methods
Re: Cranking Compression? [Re: emarine01] #641617
03/16/10 08:52 PM
03/16/10 08:52 PM
It came real close once I added the 40* (which I didnt
read before)... I guess you need to read the directions...LOL
Re: Cranking Compression? [Re: MR_P_BODY] #641618
03/16/10 09:11 PM
03/16/10 09:11 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
hehehe, when i did it the first time, i didnt read the destructions and came out to something like 300 psig
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Cranking Compression? [Re: cudadon] #641619
03/17/10 12:03 AM
03/17/10 12:03 AM
Missouri
galen Online content
galen  Online Content
Missouri
Mike using the calculator on the Not2fast.com site you gave. I punched in 10.20comp.4.150 stroke.6.76 rod. My cam card list duration on intake at 296, or 263 at.050. So I put in 296. 0 alt. 70 degree temp. says I should have 152, Mine runs 155 average cranking. Close if I am right with the duration number.
Re: Cranking Compression? [Re: mopar dave] #641620
03/17/10 01:38 AM
03/17/10 01:38 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
whats the volume to pressure index representing or what does it mean?
That's so kewl!
They "borrowed" it from my (copyright-protected) site.
It's the DCR times the actual trapped cylinder volume times a .6% correction factor to approximate low speed torque for converter stall purposes,etc.
Boffin Emeritus
Re: Cranking Compression? [Re: polyspheric] #641621
03/17/10 06:56 AM
03/17/10 06:56 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
i used the not to fast one on my
4.15 crank
6.670 rod
12 to 1 flat top with a .484 mp hyd cam
shows cranking pressure of 200
and when i built it last year with file fit rings it showed 180-185 every cyl
Re: Cranking Compression? [Re: n_bogie1984] #641622
03/17/10 08:17 AM
03/17/10 08:17 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
4.15 crank
6.670 rod
might have 12:1 flat top pistons BUT what is your actual compression ratio? could be much lower than 12:1 if the block wasnt decked, head volume cc'd, too thick of a gasket etc....
Page 3 of 3 1 2 3
