Re: Cranking Compression?
[Re: roadhazard]
#641578
03/16/10 09:42 AM
03/16/10 09:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If anyone knows their cranking compression and can test that calculator PLEASE let me know if its even close
[Re: cl440]
#641580
03/16/10 09:51 AM
03/16/10 09:51 AM
MR_P_BODY
It is a bit confusing to me? For stroke it says "Same units as rod length" and for Rod length it says "Same units as stroke" so do I enter rod length for stroke and stroke for rod length?
I was thinking they meant metric or american
[Re: MR_P_BODY]
#641581
03/16/10 10:00 AM
03/16/10 10:00 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
You may be correct?
I can say that our 528 Aluminum block has 155# of cranking pressure with the engine warm. This is with a tight lash long duration (290 @ .050) .650 lift solid cam and 13:1 compression and 440-1 heads. Is that where it is supposed to be???? I dont know for sure but we were happy with its performance and it made its fastest pass of the season at the last race last year.
[Re: MR_P_BODY]
#641582
03/16/10 10:04 AM
03/16/10 10:04 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Mike,
If you can use an excell spead sheet, pm me your private email address and I will send you a file that will do this.
8.30's @3400 lbs
[Re: cl440]
#641583
03/16/10 10:09 AM
03/16/10 10:09 AM
MR_P_BODY
Well it says for mine I should be seeing 307 psi cranking pressure(no way) I just did a compression test and its 150 in 1 cyl and as high as 175 in another with a average of 165 and based on the cranking pressure I would have 9.4 compression ratio.... I'm going to do a leak down in a little bit also... I know when I built the engine I had a leak rate of just under 3% (between 2.5 to 2.8 percent)
[Re: Mike Swann]
#641584
03/16/10 10:10 AM
03/16/10 10:10 AM
MR_P_BODY
Mike,
Thanks Mike mracerraff@aol.com
[Re: cudadon]
#641586
03/16/10 10:15 AM
03/16/10 10:15 AM
MR_P_BODY
mike compr. is a relative test. cam timing / bleed off has a lot to do with it. if the cyls are within 10-15% thats ok. leak down will tell if the cylinder/valves are sealing good. Don
That I know and thats why I dont want to go by that calculator above... it doesnt ask the IVC point which is a must know
[Re: cudadon]
#641587
03/16/10 10:18 AM
03/16/10 10:18 AM
Posts: 2,930 A shed in England
Tig
A shed in England
I don't know how it did it On the gauge we had around 125 psi (cam installed as per card) the calculator showed 126psi
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Dodgem]
#641589
03/16/10 10:28 AM
03/16/10 10:28 AM
Tig
A shed in England
This one seems to be real close http://www.rbracing-rsr.com/comprAdvHD.htm
30+ psi off with that one I'm scratching my head now
[Re: MR_P_BODY]
#641594
03/16/10 11:20 AM
03/16/10 11:20 AM
Posts: 2,516 PA
moparacer
PA
Wallace has about every calculator you would ever need.
They have a dynamic and effective comp calculator.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#641595
03/16/10 11:28 AM
03/16/10 11:28 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I use the KB site one. It's simple (aside from remembering the negative figure for dome volume/positive deck height) and is within 20psi of my results in most cases.
[Re: mopar dave]
#641597
03/16/10 12:28 PM
03/16/10 12:28 PM
MR_P_BODY
Well with checking all the different calculators and doing a compression check MAYBE I dont have the compression I thought I had.... I cant believe I was that far off when I checked the measurements when I built it.... it comes up with a 9.5 compression ratio on just about all of them..... I did a leak down and that showed pretty decent, from 2% to 7% ... no wonder I'm not making the power I figure it should
[Re: MR_P_BODY]
#641598
03/16/10 12:34 PM
03/16/10 12:34 PM
Thumperdart
State of confusion
Too many variables..........just test it and you`ll know for sure. My experience shows that big duration cams w/lots of overlap generally show lower numbers for example: my 360 w/a dur. of 255@ .050 cranked bet 190-200 cold. My 470 w/275-280 dur.@.050 cranks bet 170-175 and my buddys low 8-sec chevy small block w/a BIG roller(don`t remember #`s) cranks at 155 or so.
[Re: mopar dave]
#641603
03/16/10 01:54 PM
03/16/10 01:54 PM
MR_P_BODY
Thats the one thing ... I dont have a degree at 0, my cam card only has .050 for the valve timing and my cam is a 276/284
[Re: AndyF]
#641609
03/16/10 04:00 PM
03/16/10 04:00 PM
MR_P_BODY
I don't see how you can work backwards to CR from cranking compression. Put a 16V system on there and the cranking compression will go up due to the faster cranking speed. Pull all the plugs and pull the carb off the intake and the cranking compression will go up a bunch. Do it warm and the cranking compression will go up.
One of the calculators stated it for a 300 crank RPM and I am assuming they do some magic calculations to come up with a number
[Re: MR_P_BODY]
#641610
03/16/10 04:13 PM
03/16/10 04:13 PM
Posts: 15,491 the boonies
aarcuda
the boonies
i used http://www.not2fast.com/turbo/compression/cranking_pressure.shtml for intake opening I only have .050 also. in the instructions it says to add 40 (thats 20 degrees x 2) to the duration at .050 so i did and it came out to 166. my cranking pressure is surprisingly 165
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: MR_P_BODY]
#641613
03/16/10 07:29 PM
03/16/10 07:29 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I don't understand any of this stuff you all are WORRYING about. If the engine was put together and you KNOW what the static compression is/was/should be,,,you are not going to change that figure with all these 'calculations'. A leak-down test will show you if there is a problem in the valves/rings/headgaskets etc. Why worry and ask questions about your engine? If the leakage is high,,you have a problem in that cylinder.....simple enough I think.
If you like drag racing, support your local track.
[Re: CHAPPER]
#641615
03/16/10 08:12 PM
03/16/10 08:12 PM
MR_P_BODY
Pretty simple really.... I was going to do a compression test and wanted to know what it should be... thats all, I wanted to do the compression test before I pulled the rockers to do the leak down
[Re: emarine01]
#641617
03/16/10 08:52 PM
03/16/10 08:52 PM
MR_P_BODY
I think once you have your intake closing point close for the calc it should fall with in 10 psi of your gauge reading, the calcs are a little confusing on the duration methods
It came real close once I added the 40* (which I didnt read before)... I guess you need to read the directions...LOL
[Re: mopar dave]
#641620
03/17/10 01:38 AM
03/17/10 01:38 AM
Posts: 4,209 New York
polyspheric
New York
whats the volume to pressure index representing or what does it mean?
That's so kewl! They "borrowed" it from my (copyright-protected) site. It's the DCR times the actual trapped cylinder volume times a .6% correction factor to approximate low speed torque for converter stall purposes,etc.
Boffin Emeritus
