Re: Whats the best tranny pan gasket for 727 ?????
[Re: 1_WILD_RT]
#632928
03/07/10 05:37 PM
03/07/10 05:37 PM
Posts: 32,947 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Most dealers have them on the shelf as it fit Dodge trucks up till very recently...
They fit the A518 trans.
[Re: stumpy]
#632929
03/07/10 09:32 PM
03/07/10 09:32 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I never had a problem with cork. Thats what Ive always used. No sealer, no seep, no drip
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#632930
03/07/10 10:12 PM
03/07/10 10:12 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
THERE you go ... cheap and no seep ..
JUST make sure you have a straight and flat pan-rail and do NOT over-torque the bolts.
I have had the same CORK gasket on my 62 since the mid-70's ....had the pan off numerous? times .. no SEEP ...and cheap.
[Re: Chilort]
#632932
03/08/10 09:51 AM
03/08/10 09:51 AM
Posts: 1,067 Newton, KS
70B5Cuda
Newton, KS
Anyone have the part number for the mopar one?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: NITROUSN]
#632934
03/08/10 11:32 AM
03/08/10 11:32 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Get the Mopar reuseable one from a dealer.
Those do not work on all 727's there are differences in casting along the front sealing edge. Mine leaks from there and found out the deal from John Cope during his seminar, I am going back to a regular cork/neoprene gasket
[Re: Moe]
#632936
03/08/10 12:17 PM
03/08/10 12:17 PM
challenger70
Berwyn, IL
You are supposed to put the new Mopar gasket on dry. I did, and it leaked live a sieve. I have an aluminum trans pan. Going to use "The Right Stuff" when I re-use it.
You probably have the same year(s) trans I do, check the front of the gasket with the contour of where it seals to the trans I bet they do not follow each other. Not sure if it's better to goop on sealant or just use a standard gasket.
[Re: Chilort]
#632938
03/09/10 10:50 PM
03/09/10 10:50 PM
I've built thousands of transmissions, ONLY use cork, and have NEVER had a leak from the pan gasket........Like already mentioned, the pan rail needs to be flat and then tighten correctly..... Wayne
