Whats the best tranny pan gasket for 727 ????? #632920
03/07/10 02:33 PM
03/07/10 02:33 PM
dark side of the moon
Dougsmopars Offline OP
I'm looking to see what you guys think is the best tranny pan gasket for a 727. Time for a fluid change.
Re: Whats the best tranny pan gasket for 727 ????? [Re: Dougsmopars] #632921
03/07/10 02:34 PM
03/07/10 02:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Get the Mopar reuseable one from a dealer.
Re: Whats the best tranny pan gasket for 727 ????? [Re: NITROUSN] #632922
03/07/10 02:41 PM
03/07/10 02:41 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
agreed on that Mopar gasket.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Whats the best tranny pan gasket for 727 ????? [Re: MonGoo$e] #632923
03/07/10 02:44 PM
03/07/10 02:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Whats the best tranny pan gasket for 727 ????? [Re: stumpy] #632924
03/07/10 02:52 PM
03/07/10 02:52 PM
BDW Online content
BDW  Online Content
Expensive but worth every penny.
Re: Whats the best tranny pan gasket for 727 ????? [Re: BDW] #632925
03/07/10 02:59 PM
03/07/10 02:59 PM
Works for me. I'll order up one tomorrow. Thanks
Re: Whats the best tranny pan gasket for 727 ????? [Re: Dougsmopars] #632926
03/07/10 03:08 PM
03/07/10 03:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Most dealers have them on the shelf as it fit Dodge trucks up till very recently...
Re: Whats the best tranny pan gasket for 727 ????? [Re: 1_WILD_RT] #632927
03/07/10 05:18 PM
03/07/10 05:18 PM
bristol tn
jbcuda Offline
jbcuda  Offline
bristol tn
i have aftermarket pan tried cork ,rubber,gasket maker and all would not give me 100 percent seal. so i got the one from dealer worked great!
Re: Whats the best tranny pan gasket for 727 ????? [Re: 1_WILD_RT] #632928
03/07/10 05:37 PM
03/07/10 05:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They fit the A518 trans.
Re: Whats the best tranny pan gasket for 727 ????? [Re: stumpy] #632929
03/07/10 09:32 PM
03/07/10 09:32 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I never had a problem with cork. Thats what Ive always used. No sealer, no seep, no drip
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Whats the best tranny pan gasket for 727 ????? [Re: 69L78Nova] #632930
03/07/10 10:12 PM
03/07/10 10:12 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
THERE you go ... cheap and no seep ..
JUST make sure you have a straight and flat pan-rail and do NOT over-torque the bolts.
I have had the same CORK gasket on my 62 since the mid-70's ....had the pan off numerous? times .. no SEEP ...and cheap.
Re: Whats the best tranny pan gasket for 727 ????? [Re: dOc …] #632931
03/08/10 02:37 AM
03/08/10 02:37 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
The new one, like what has been said. But not torqued to 150 inlbs or so as specified. I go about 80-100 inlbs.
Re: Whats the best tranny pan gasket for 727 ????? [Re: Chilort] #632932
03/08/10 09:51 AM
03/08/10 09:51 AM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
Anyone have the part number for the mopar one?
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Whats the best tranny pan gasket for 727 ????? [Re: 70B5Cuda] #632933
03/08/10 11:04 AM
03/08/10 11:04 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
2464324AC
My
Own
Personal
Adrenaline
Rush
Re: Whats the best tranny pan gasket for 727 ????? [Re: NITROUSN] #632934
03/08/10 11:32 AM
03/08/10 11:32 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Those do not work on all 727's there are differences in casting along the front sealing edge. Mine leaks from there and found out the deal from John Cope during his seminar, I am going back to a regular cork/neoprene gasket
Re: Whats the best tranny pan gasket for 727 ????? [Re: 70B5Cuda] #632935
03/08/10 11:42 AM
03/08/10 11:42 AM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
You are supposed to put the new Mopar gasket on dry. I did, and it leaked live a sieve. I have an aluminum trans pan. Going to use "The Right Stuff" when I re-use it.
Re: Whats the best tranny pan gasket for 727 ????? [Re: Moe] #632936
03/08/10 12:17 PM
03/08/10 12:17 PM
Berwyn, IL
Berwyn, IL
You probably have the same year(s) trans I do, check the front of the gasket with the contour of where it seals to the trans I bet they do not follow each other. Not sure if it's better to goop on sealant or just use a standard gasket.
Re: Whats the best tranny pan gasket for 727 ????? [Re: challenger70] #632937
03/09/10 12:18 AM
03/09/10 12:18 AM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
I noticed that the new Mopar gasket didn't match up with my pan but it did match up with my trans. I've got 3 727s all '70 and older and all my pans look like this. I decided to give it a try anyway. So far so good and I've put about 100 miles on it. I'm thinking of getting a deep pan anyway so I can reuse this gasket.
Re: Whats the best tranny pan gasket for 727 ????? [Re: Chilort] #632938
03/09/10 10:50 PM
03/09/10 10:50 PM
I've built thousands of transmissions, ONLY use cork, and have NEVER had a leak from the pan gasket........Like already mentioned, the pan rail needs to be flat and then tighten correctly.....
Wayne
Re: Whats the best tranny pan gasket for 727 ????? #632939
03/10/10 03:05 PM
03/10/10 03:05 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Wayne
with this however one of the big pluses with the new reusable gaskets is you can use it over and over and over for years to come try that with a cork or fiber gasket.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
